POWER LOSSES THRU 4WD TRANSMISSION
#86
Originally Posted by xr2i-carl
????????????????? m5 ??????????????????
made 360 and 444..
bear in mind the big BM's never make the full power quoted
#87
Originally Posted by martin-reyland
Originally Posted by marco polo
hi shaun
all the vc's had 50Nm of torque when they left the factory
marco
marco
yes they did Rear VC's had 50Nm 2wd/4wd
the 4wd saff center diff has 25Nm
and the escort 4wd center VC has 50Nm
marco
#88
In answer to the original question, the 2wd car will MURDER the 4x4 one with equal flywheel power once rolling.
well thats a good idea
marco
#90
made 360 and 444..
#93
But i guess an extra 15bhp should even it up.
#95
1st to 200 without NOS
hi shaun
marco
marco
marco
#96
Originally Posted by BigErn
As far as Im aware you lose 40% power through 4x4 transmission from flywheel to road wheels. Not sure of 2wd losses.
And 40% would be HUGE !!!
#97
hi shaun
the cossie 4wd tranny loss can be improved by removing all the pig iron
marco
marco
shaun
if you was to put a brand new cossy on the rollers 4x4 where nothing was worn out ie , gearbox/diff/front diff/prop front/rear/center vc/drive shafts/cv ect there wouldn't that much tranny loss compaired to a 10 yr old cossy thats what i'm saying
marco
#99
escort mk4 cossy 4x4
#100
hi shaun
marco
marco
marco
i should have double checked what i wrote
#101
hi shaun
marco
marco
shaun
marco
#102
#104
#107
Originally Posted by Turbosystems
if we took out your engine and harnessed 550 red rum horses to your car would it do 190mph at brunters
what would be the et and terminal at santapod lol
The horses would be shod with road legal yokohama horse shoes
#108
I can't imagine the driveline loss to be more than 25% on a 4wd cossie. Last summer I dynoed my car (4x4 3dr replica) and the numbers were 258hp/284tq at the wheels, 4th gear pulls. With the percentage added for driveline loss that would put me almost exactly at the figure Karl quoted me for my setup when I got my chip from him.
At the rolling roads/dynos there in the UK who decides what the percentage loss is when setting up the machines to measure BHP? Is it a standard industry figure/formula or is it a random number applied by the individual operator? Whar gear are the runs usually made in?
#109
When i said drive chain, i meant transfere box, prop, diff, drive shafts.
Would be good to test the resistance, But that would mean modifie'n a RR so both roller are chain connected, so even when in 2wd mode, the fronts are being turn'd at same speed as the driven rear wheels, which this should show the rolling resistance drain on the power output.
#110
saff is working!!!...atm
#111
We need to be using wheel figures here, same as the rest of the world. Thats what dynos measure in the first place.
As for the Skyline boxes....only the R32 box has true 2wd mode. The R33 and R34 always have some degree of drive to the front wheels, even when zero pressure is applied to the diff.
#112
#113
#114
But normally, R33 and R34 do still put some drive to the fronts at all times. I dont know how much though. He says its still ok for burnouts etc with a line lock though.
Initially I was searching for an R32 box, but ended up with an R33 as they are supposedly stronger, and generally better.
I also noticed on another forum, where the skyline guys actuallly have a manual pump, to ensure 4wd is engaged on the launch. The normal controller must be a little slow on the take up to engage 4wd. They have a additional hydraulic system via a handbrake style laver to pump the diff up.
#115
But normally, R33 and R34 do still put some drive to the fronts at all times. I dont know how much though. .
#116
He isnt the only person to have said similar.....
As I have no direct experience using one yet, I cant say. But I'd think someone that works on them for a living, might have an idea about them ??
Are you saying all of them are fully open then ?
#117
your informant is wrong mate,the skyline 2wd to 4wd works via gyroscopes and accelerometers/decelerometers. ie it sets off in 2wd,the sensors signal the car is moving and then engages 4wd.you would be surprised how many skyline tuners i have spoken to who dont know how the system works.
#118
As Lloyd mentioned above there are a great deal of people in the Skyline business that don’t completely understand how the system works .. Particularly the hyd valves etc, I know this because at the start of the project we were given some very bad advice by more than one tuner which resulted in damaged pump/valves.
#120
The reasons you mention above, are why some of the skyline drag racers, have a manual pump, to engage 4wd before setting off on the 1/4, as the system can be lazy to engage 4wd, and hence lose traction off the line.
I simply asked how hydraulic pressure affected the diff and what was required to make full 4wd as per skyline car, and was it fully open when zero pressure was applied. I was told that only the R32 was fully 2wd.
And to fully engage 4wd requires circa 180-200psi.
I would be surprised if he is wrong, as he is one of the people who built Kieths car.
Perhaps there is a mis-communication somewhere...
