EsCos Weight Distribution......
as above anyone know the front/rear weight distribution of a standard motorsport model EsCos? and if anyone knew the side to side (if there is a difference) then that would be amazing.
Cheers in advance.
Cheers in advance.
Originally Posted by mk2rstaff
go on google and find the esc cos web page mate it will be on there
no mate had a look but nothing of the sort in there, there is a site i found but its under construction at the mo
my standard ST Escort Cosworth with bolt in roll cage was 1350Kg. unfortunately I didn't get the corner weights.
The only other info I have is after removing seats, carpets etc, not much good if you have a road car. However here it is.
with me in the car, I'm 83Kg and 15ltr fuel in tank.
Front R 330kg.
Front L 370kg.
Rear R 249kg.
Rear L 260kg.
My car is LHD and the front doors were still steel, the doors weigh up to 40Kg the pair.
Front R 330kg.
Front L 370kg.
Rear R 249kg.
Rear L 260kg.
Front R 330kg.
Front L 370kg.
Rear R 249kg.
Rear L 260kg.
Front R 330kg.
Front L 370kg.
Rear R 249kg.
Rear L 260kg.
wowk
30-03-2021 07:49 PM
