URGENT help needed. My s1 wont run.....
GASH!
Hello, wondering if anyone can help me as im now stuck at work.
Went to start the s1, and it run for about 3 secs, then just died out. now, whenever i crank it, it runs for about 2 secs, then dies out completely, even with my foot flat on the floor. Its sucking air, and there is no smell of petrol.
The fuel pump is priming, and i have half tank of fuel, so im pretty sure its not them. Any quick help would be good.
Mike
Mike
Right as daft as it sounds my mate had this on my old series 2 and the pipe had comne off either the actuator or the turbo housing as the bleed valve came un clipped and the bleed valve being heavy the weight of it had pulled the pipe off hope this helps cheers, Grant
Boxxer its Alan s1 Remove the hose from the bottom of the metering unit see if it has fuel in it thats whot mine was doing
Run then it lost preasure in the as a Gaskit goes
If you still have my number give me a call im working untill 3am
GASH!
RIIIIIIIIGHT! back at home now, lol. I took off ALL the sensor clips, and cleaned them out, and made no difference, so turned to looking at the metering head, and took the air filter off. There was a small amount of fuel in the bottom. So i moved the plunger up and down about 50 times, then tried to start the car. It didnt go first time, but went and ticked over on its own. So refitted the filter, and now its running better than ever. Weird. The ultimate test will be in the morning and starting it from cold, as thats when it used to be at its worse.
Can you overhaul those MFI systems?
Cheers for all ya help
Mike
Mike
GASH!
Originally Posted by SI-S1
i had that prob on my S1 was the silver relay
Mike
Originally Posted by boXXer
Originally Posted by ricky_3dr
Got it sorted????
You don't mean that That's what ya get for messing about with old Fords
DaveN
13
09-01-2005 06:19 PM
