swirl pots
Old 26-12-2006 | 11:49 PM
banhambuilt's Avatar
banhambuilt
Default swirl pots
just been reading a thread about foam filled tanks and swirl pots were mentioned.
i don`t know bugger all about them
are they needed?
how many inlets/outlets?
i will be running 2 small alloy tanks on the rs200 (no room for a large 1).
i understand that i will need a feed to the pump,filter,regulator then fuel rail.
then i will need a return to the tank
cheers
dave
Old 26-12-2006 | 11:59 PM
Alan s1's Avatar
Alan s1
Umm i have a Foam Filled tank to go in the cossie (standard cossie tank ect just with foam) I am going to be fitting that so would like to know if i also need a swirl pot but going by my merory (which isnt to good ) a m8 had a Ex police van Transit with a V6 init and he said that had a foam filled tank but he did'nt say any thing about a Swirl pot
Old 27-12-2006 | 12:06 AM
Fast Guy's Avatar
Fast Guy
A swirl pot (surge tank) will depend on how much fuel you're planing to use.
On a low powered car you won't need one, but as you're talking foam filled tanks then I take it your power isn't going to be so low? I think one correctly size swirl pot should do. but I'm sure someone could be more specfic.
S1's Avatar
S1
You will need a swirl pot whether its in the tank or external. It prevents the fuel system from running dry under extreme cornering or/and low fuel levels.
Old 27-12-2006 | 12:09 AM
Alan s1's Avatar
Alan s1
Thats whot i fort
Old 27-12-2006 | 12:23 AM
NUTS RuS's Avatar
NUTS RuS
see my reply on the other thread Dave
inlets / outlets depend on how and where it is placed or how many pipes you plan to run
Old 05-01-2007 | 07:40 PM
banhambuilt
i have had a change of tack on this,i had made 2 dummy tanks out of thin steel (so they could be copied)
but i noticed something on ebay the other day,that might be better and with a bit of history.
it was a group A genuine ex works rally car safari spec premier bag tank with alloy cover.just what the rs200 needs,proper motorsport parts
you never guess what, i won it
has fitment in the middle for 2 primary pumps.
luckly i bought these the other day.
so hopefully it should just be a case of mounting this as low as possible in the chassis.
running 2 low pressure fed lines into the swirl pot and a high pressure pump feeding the outlet to the engine.
think i have it covered now,bar the swirl pot.
dave
timsrs
13-11-2018 12:48 PM
mk1turboestate
02-12-2015 09:31 PM
01-11-2015 07:53 PM
155lee
27-10-2015 05:55 AM
IainRS1700T
25-09-2015 07:44 AM
Quick Reply: swirl pots
