5 stud hubs
Yep, granny hubs, 5x112 pcd and still a 63.4 centre hub size. Rear brakes from a 24v are the same diameter as 4x4 cossie but the fronts are only 278mm and only as 2wd offset so a big brake upgrade would need to be done to look good. Suppose it will give ya a wider range of wheels tho as the stud pattern is the same as Mercs and some Audi's
Resident Wrestling Legend
granada hub flanges only, the 4wd granada's are getting pretty rare on the ground so if you want them get them found ![Grin](https://passionford.com/forum/images/smilies/icon_smile.gif)
or you can buy new ones for about £100 each side, but you will need new bearings on the fronts, the rears might just be doable but for the money you might as well get them done too
seen loads of sierra xr4x4's with this done and have done it myself about 2.5 years ago so once you've figured out how to get the brakes to fit (redrilling the driscs to the granada pattern is easiest or get your bells done with a big disc kit) it's all systems go
To fit beemer wheels you need to swap over to the 4x4 grannie hubs but as these are not the same pcd as the beemer wheels you then need to add a set of 5 to 5 hub converters to match the bigger pcd - obviously this widens the track and could cause rubbing issues
You cannot go from 4 to 5 via a hub spacer as the holes clash unless you go so thick that they dont, but that involves a 50mm plus spacer so you would end up looking like one of those pumped up 4x4 jap 80,s rhino things beloved of the Ali G types
So...will it be possible to convert a 2wd Sapp Cosworth to 5 studs.... ?
And if so how much is needed to do it ... ? And will offset be changed ?
the bits with the studs sticking out are all you need to change
but obviously this means undoing the hubs nuts and removing the bearings etc
hence the reason you just need to source a set of hub flanges and swap them into the existing carriers
any granada will do as they are all the same, you may be able to source a complete car for the cost of getting the bits you want, i regulalry collect cars for free, strip them of bits and then get someone to collect the remains and the cheapest i've bought a whole complete running granada for is £22 off of ebay and i've collected a free one too, if i had known these parts were in such high demand i would have taken them off, only one nut and out they come
i'll see if i can find a picture of the old hubs i sent off
THE RADMAN
I have looked in to this and this is what i found out and is probley the best way to go.
you can keep your studs and just use a spacer with different pcd, 5 stud instead off 4, just might need to get them made up to what you want, only thing you need to check is the wheels that you whould like to fit come in an off set off about et 35 min as you will need 20 / 25mm for the spacer
cheers dunc
cheers dunc
K155MYRS
Originally Posted by Stavros
Shame cant go to 5x114.3, ie Jap motors, then you can FINALLY get some properly cool rims.
We have some ARP wheel studs in stock that solve many 5-lug conversion problems. These wheel studs have gigantic knurl diameters, and if you start with Scorpio(that's our American Granada) stuff all you have to do is drill the 5x114.3 bolt pattern over the existing 5x112 holes. The knurl is so large that the old holes are completely engulfed by the new holes. Easy!
http://www.machine7.com/product.php?xProd=1168&xSec=601
The Vdub boys have been changing bolt patterns for years
DEYTUKURJERBS
Originally Posted by jungleistmassiv
my mk3 mondeo is 5 stud. Also has 300mm discs up front too standard ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
the granada's are 112
![](https://i102.photobucket.com/albums/m119/dojjindia/escos/hubrearsierra.jpg)
this is a rear hub from a sierra
you will see that it's got 2 access holes for the hub carrier bolts to come out through
on the granada rears there are 3 so you can't redrill them
the shaft is where the bearing sit and these are the same as on the granada and sierra's so they are interchangable
on the 4wd fronts you will have the same arrangement BUT due to the difference in splines (i think, i'm not well so i can't go to the garage and find out for sure, it might be the actual shaft lengths) you can't just bolt the rears to the fronts
on the 2wd versions the bits where the bearings go are swapped for a threaded section so that you can tighten them up from behnd the cap on the hub rather than at the face of the hub
hope that amkes things clearer for you
yes mate
rear bearings are easy, you just need to find something that will undo them and then tighten them up again to something like the 220ft/lbs they need to go to
the fronts i've never done so i couldn't tell you how to do them, but if the abs ring is seperate then you might wan to make sure things go back in again the same way (on the 4wd cars they are integral with the drive stubs as are the rears)
