best turbo for cossie ???
Old 20-12-2006, 12:27 PM
sygjim
sygjim's Avatar
Default best turbo for cossie ???
In performance ford january 2007, there is a test of a roll bearing t34 from turbo dynamics
very impressive
it had been tested on a 500cv spec motor, and they had compared standard t34 and roll bearing t34.
2300 rpm and 2 bar at full throttle
and 480 hp
what do you think about this turbo ?
Old 20-12-2006, 12:37 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
looks incredible dont it
but then again the MD240R looked incredible too when you read the PF tests on that back in the day, and in reality it was a surge-tastic loada crap.
cant wait for someone to try it on a car, as if its as good as it seems, its properly properly good...
Old 20-12-2006, 01:05 PM
rapidcossie
rapidcossie's Avatar
cant believe it gets 2 bar at 2300 rpm
its some dyno jiggery pokery there i think.
stick with tried and tested
Old 20-12-2006, 01:10 PM
Nash
Cake lover!
Nash's Avatar
Surley if its got a roller bearing then why havn't they called it GT34?Doesn't this mean that it has the problems like GT series turbos where if one part failed the whole thing needs to be replaced?
I know from when people where switching from T28's to GT28's it only came in about 300rpm sooner. If someone fits it and i see a graph for it i will stand corrected.
Old 20-12-2006, 01:13 PM
Porkie
Porkie's Avatar
Looks AMAZING that Turbo!!!
Just mental... But.... I will remain slightly sceptical until it hits a few cars.
Can't wait to see someone try it or a hard used road/track car though
Old 20-12-2006, 01:26 PM
Nash
Cake lover!
Nash's Avatar
When something usually sounds to good to be true it usually is.
What do most people usually get out of a GT30 on a cossie, out of interest?
Old 20-12-2006, 01:50 PM
sygjim
sygjim's Avatar
this t34 as the same exhaust side than a standard t34 0.63, so i think that it's easiest to fit then a gt30
yes, the motor was map and has a 4*4 exhaust manifold
pete mcrash
saff is working!!!...atm
pete mcrash's Avatar
think a gt30 is good for 500 ish bhp
Old 20-12-2006, 02:01 PM
Martinshuter
Martinshuter's Avatar
i run a GT30 on my saff, power about 440bhp but ringing the neck of the grey injectors
Old 20-12-2006, 02:02 PM
Stavros
DEYTUKURJERBS
Stavros's Avatar
Same as.
And GT28s have newer spec wheels etc. Every time ive seen just the core changed to BB and identical wheels n housings, nothing changes.
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
I read about this and thought 480hp....
Good, But like porkie says, Wanna see it on a few more cars
Old 20-12-2006, 02:08 PM
Mike Rainbird
Caraholic
Mike Rainbird's Avatar
Same as.
What he said.
When you compare apples with apples (identical turbos with nothing changed other than bearing type), there is absolutely NO difference in spool up (back to back T4 comparison).
Obviously if you compare apples with oranges (bigger housings, different trim wheels etc), unsurprisingly you are going to notice a difference .
Out of curiousity, what sort of friction difference do you think is generated out of running the shaft in a bath of oil compared to roller bearings?
Please be aware that I am NOT slating the turbo, as it did look VERY good. I am just pointing out that roller-bearing cores do not give faster spool-up. This is achieved with different design of turbo (smaller, lighter shaft and more efficient turbine design) and NOTHING to do with the roller bearing core.
Old 20-12-2006, 02:09 PM
sygjim
sygjim's Avatar
yes, with the same motor 400 hp with t34 and 480 with t34 with bearing
Old 20-12-2006, 02:10 PM
CossieRich
Did Someone Mention TUV
CossieRich's Avatar
480 bhp from a T34? Surely making it roller bearing doesnt change the fact that it cant flow more air
Old 20-12-2006, 02:11 PM
GARETH T
GARETH T's Avatar
one word,,, BOLLOCKS
Old 20-12-2006, 02:12 PM
pete mcrash
must have gone to well lane.....lol
Mike Rainbird
Caraholic
Bollocks!
Go and read the article again and NOTE THE TRIM CHANGES FROM TURBO TO TURBO!
Ian M500COS
Ian M500COS's Avatar
I was thinking along the same lines
Old 20-12-2006, 02:17 PM
sygjim
sygjim's Avatar
Bollocks!
very agressive !!!!!!
yes, it's an hybrid with a gt, so, it's an explanation of the power difference
they named it t34, but it's not a t34, i am agree
Old 20-12-2006, 02:25 PM
Mike Rainbird
Caraholic
Bollocks!
Just trying to stop you from perpetuating the myth about roller-bearing cores .
The turbo is very good (by the looks of it), but this is down to it's superier internal components and nothing more magical .
Old 20-12-2006, 02:30 PM
CossieRich
CossieRich's Avatar
Mike or anyone else
What trim is this "t34" and how is it capable of flowing enough air for 480 bhp. Is there a compressor map for it?
Old 20-12-2006, 02:31 PM
Ian M500COS
Perhaps it's not the turbo "making" the power.......
Old 20-12-2006, 02:37 PM
Mike Rainbird
Caraholic
Originally Posted by CossieRich
Mike or anyone else
Go and buy the magazine you fucking cheapskate (revenge is SWEET!)
Old 20-12-2006, 02:49 PM
CossieRich
CossieRich's Avatar
Mike or anyone else
What revenge is that then? I dont remember offending you this week yet
Old 20-12-2006, 02:51 PM
Mike Rainbird
Caraholic
Mike or anyone else
You've been trying to on other threads . I just treated you with the comtempt you deserve and ignored them .
Old 20-12-2006, 03:08 PM
cheeky dog
cheeky dog's Avatar
thats like the third tme i've heard something sarcastic about well lane?????? anyone care to xplain??
Old 20-12-2006, 03:22 PM
CossieRich
CossieRich's Avatar
Mike or anyone else
Deep down, i know it annoys you and you are dying to say something. Now stop being a silly twat and answer my question please
Old 20-12-2006, 03:33 PM
pete mcrash
....anytime u put up a power figure from well lanes rollers....people say there bolloxs....i've used them 3 times....but i will be putting my car on a different set to compare figures....
Old 20-12-2006, 04:53 PM
Fiecos Dan
Fiecos Dan's Avatar
Same as.
i agree with that, Thats why i dont think this test was fair,
ps i think it is a similar if not the same spec MD 240r used in the test.
Heres what i said while decussing the actical with PF Dave
Originally Posted by fiecos dan
Just read the mag,
Good read as always Dave, Nick and the pf team.
but i think the turbo feature is abit miss leading. (not digging, just my opinion)
As what i can see,
-2 different spec turbo's, two different spec actuators on the same map / engine. As this can have boost issue's related to the boost controll, not the Turbo.
To be fair, the turbo spec's would need to be the same, but with just different bearing cores, with the same actuator fitted for bost test's, with the same preload. (wastegate wired closed would of been even better).
i say this, as a T34 are alot less laggy normally. i mean 30+psi before 3300 rpm. when on correct set up, and 380+ bhp on road fuel
Old 20-12-2006, 06:00 PM
sygjim
sygjim's Avatar
ok, but 28 psi at 2300 rpm
what about gt28 and gt 30 ?
Old 20-12-2006, 09:11 PM
Fiecos Dan
Fiecos Dan's Avatar
Sorry, but thats just unbelievable. and on a worked engine.
A std T3 wont do that, let alone a GT30 sized turbo.
Old 25-12-2006, 09:15 AM
Fiecos Dan
Fiecos Dan's Avatar
Also surge will become a serious issue, with that boost/rpm.
Old 13-01-2007, 12:08 PM
M K
M K's Avatar
il have 1 fitted to my car for the berkshire rolling road day so il put the results up then
its only a 1.6cvh but was previously running a T34
i only have a previous engine dyno sheet with the standard t34 on tho not a RR print out if that makes alot of differance spose you cant compare engine dyno sheet to rolling road sheet can you?
Old 13-01-2007, 01:38 PM
Fiecos Dan
Fiecos Dan's Avatar
Good luck.
but your right, about the engine dyno, and a RR.
ps, heres my answer on the other post in the rst section.
Originally Posted by Fiecos Dan
Originally Posted by M K
il see how mine differs from standard t34 at the berks rolling road day
Please do.
But have you boost/rpm checked your T34 @ every 100 rpm, under full load in the car?
and on the same actuator, boost controll, and same full spec and same weather conditions, but just the turbo changed, do the same on the new turbo.
Old 13-01-2007, 02:35 PM
Rick
Rick's Avatar
MK - can you post ur dyno sheet please
Old 13-01-2007, 04:32 PM
_DAN_
Yoon
_DAN_'s Avatar
What is the problem with the MD240R?
Old 13-01-2007, 05:04 PM
GARETH T
GARETH T's Avatar
nothing at all,,,, that is if your in the business of
Old 13-01-2007, 05:12 PM
_DAN_
Yoon
_DAN_'s Avatar
Fucking hell!My sides.
Why does it surge alot?
OT I know,but relevant here.
Old 13-01-2007, 05:18 PM
GARETH T
GARETH T's Avatar
i got another one,, but i think ill save it for a rainy day
the problem is that it has a realtive small exhaust housing compared to its compressor sizing! someones tried to lower the boost threshold by using a small exhaust housing and sadly what you end up with is surge!
btw boost threshold is the point in the rev range where the turbo starts to make positive pressure,, most poeple call this lag,, but it isnt,,, lag is the time it takes for the turbo to spin upto speed when in the correct operating rev range
Quick Reply: best turbo for cossie ???
