sierra front suspension removal???
ELASTIC BAND
got a koni adjustable set up, how do you get it off?
the bottoms completely free ( no front hubs etc ) and up the top theres a 19mm lock nut that just turns with part of the suspension?
Did my friend a few months ago. The threaded bar that goes through the top nut should have a fitting that take an 8mm (i think) spanner (allen key on standard shocks). You hold that while you loosen the nut- that stops everything just spinning round.
ELASTIC BAND
Originally Posted by dojj
put the bottom back on again
put some wieght on the suspensino
they, if that fails, put the grips on with a big wad of cloth on the shaft
heres the top, aint got no mole grips, so will have to try and borrow some, allso need a deep 19mm socket which i aint got!
ELASTIC BAND
Originally Posted by Lee_R21Turbo
Fil, use a swan neck spanner on on the bottom nut & a normal spanner on the flattened edges of the thread!!
but cheers
Originally Posted by Fil
nothing to put the bottom back onto
Resident Wrestling Legend
that way you can get a bit more pressure on the actual strut to possible get it off?
failing that, use a spanner on the flats to hold it while you undo it
or burn the nylon off the nut, but this takes forever and you could end up overheating the rod
ELASTIC BAND
Originally Posted by xr_craig
Just use a spanner on it as said
had no mole grips, just borrowed some for tomorrow, no deep 19 spanner or socket and no on to borrow them off, so will try melting the nylock bit. and using a normal ring spanner tho it don't fit all that well
ELASTIC BAND
Originally Posted by rs nutter
you only need a standard 8mm open spanner for the top mate.
