5th injector setups- How do they work?
Old Dec 14, 2006 | 07:47 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default 5th injector setups- How do they work?
As per title, really, as ive not got a clue!
Ive never had any dealings with them, so its one part ive no idea of, so, teach me please!
Just the simple cheap 5th inj setups like you see on RS Turbos etc.
How is the fueling regulated?
Does it pick up on boost and rpm and go from there, or just boost, or?
Do you have to use a certain size injector or can you use even big fuckers if you wanted?
How do you adjust it?
What they cost?
How, well, everything, ive never looked at em before!
Cheers in advance
Old Dec 14, 2006 | 07:53 PM
Jim Galbally's Avatar
Jim Galbally
the controllers are like mini-mappable ECUs
you'll have a number of inputs (ie boost only or boost vs rpm etc.) and a small map (either programmed with a data cable or with a selection of switches on the ECU)
you can run whatever injector you want as long as it's the right impedence, as youre only giving a pwm output to a solenoid, the thing doesnt know/care what size it is
Old Dec 14, 2006 | 07:54 PM
Billabong's Avatar
Billabong
http://www.aquamist.co.uk/cp/mf2/mf2.html hopefully of some use Steve.
Old Dec 14, 2006 | 08:12 PM
Jasesapphy's Avatar
Jasesapphy
MSD sells his 5th injector, worked a treat to replace my TT one, basically its a boost switch that can be set from 2psi - 20psi if i remember, when the boost switch sees the boost required, it fires the injector, MSDs have 25 settings to adjust the fuel requirement
Jasesapphy's Avatar
Jasesapphy
Run high or low impedence also
manuel boeckx
13
Oct 3, 2015 02:29 PM
wheelwizardrefurbs
Aug 29, 2015 09:25 AM
Zoggon
Aug 10, 2015 10:39 AM
Perfmr2
Aug 6, 2015 07:30 AM
