Temp gauge Fitting?
Old Dec 12, 2006 | 02:46 PM
Nash's Avatar
Nash
Cake lover!
Default Temp gauge Fitting?
As above really i have a water temp gauge to install but not sure wheres the best place to put the sender on a Saph?
I had thought about putting it in the pipe where my swirl pot is with a connector from tweekies. Then i wondered if i could use the hole where the standard temp sensor is by using a T piece if thats possible. Or if anyones got a better idea where to put it that would be great.
Old Dec 12, 2006 | 02:50 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Depending on the the thread type, you can replace the existing sensor with the new one....
Old Dec 12, 2006 | 02:56 PM
Nash's Avatar
Nash
Cake lover!
And just get rid of the standard gauge?
Old Dec 12, 2006 | 03:13 PM
Mike Rainbird
Caraholic
Yes, why do you want two? The Ford one is about as accurate as sticking your finger in the water - you know it's fucking hot, but have no idea HOW hot .
Old Dec 12, 2006 | 04:02 PM
Basky's Avatar
Basky
mine runs in the block by the turbo,between 3and 4 cylinders
theres a plug there to take out,also is this supposed to be hottest part of the engine?
Old Dec 12, 2006 | 05:25 PM
Nash's Avatar
Nash
Cake lover!
Cheers Mike and Besky will get it sorted this week.
Old Dec 12, 2006 | 06:44 PM
redrsmk5's Avatar
redrsmk5
Yep you can help me with mine then
Old Dec 12, 2006 | 07:06 PM
Nash's Avatar
Nash
Cake lover!
No problems bud.
I might have to pick you bufty brain on how you polished up compressor wheel again. Well got to do something while i am off for almost 4 weeks lol.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Adam-M
Aug 26, 2015 05:53 PM
Kop2381
Aug 23, 2015 01:17 AM
mrmann
Aug 20, 2015 11:24 PM
COSWORLD
Aug 14, 2015 07:40 AM
