What's the difference between a -31 & -34 actuator?
I'm looking for a -31 actuator for my 2 wheel drive cosworth and I'm getting confused I keep seeing -34 actuators for sale and I wondered if one of them would be better and if I could use one for a stage 1 conversion
Also what is the difference between 2 wheel drive and 4 wheel drive actuators?
Please help me because I'm confused
Thanks
Thanks
-31 has base lift off pressure of approx 8psi, -34 is 14 psi (that's minimum boost).
-31 gives a nice progressive delivery of boost, ideal for stage 1.
Thanks guys. I just need to find one now <---- real
I've been looking for a 2nd hand one for weeks but I keep missing them on ebay
saff is working!!!...atm
Originally Posted by cossiecrazy
its all to do with poundage and how much boost you need -31 is for upto 330 bhp
it must be at full chat at that it will work better with -34 but its your choice im going off experience thats all at that boost he only wants stage one ???????????
Sponsor
paul send me ur addy and ill post u a 31 its used but will be fine for you stage 1 as ive just gone to a 34 actually just thought i have a 2wd 31 and a 34 4x4 spare
Paul send me ur addy and ill post u a 31 its used but will be fine for you stage 1 as ive just gone to a 34 actually just thought i have a 2wd 31 and a 34 4x4 spare
I have a Forge actuator in the garage which has a white spring in it, supposedly for 23psi. Can I hell pull the rod out on it!!
Gonna put it on mine when I get the chance. Fook knows how Ill adjust it tho!
a -31 is as mention'd a 8 - 10 psi actuator, and a -34 is a 14 -15 psi actuator.
fuckin show off
You should try and pull the rod out of that fucker.
i'm running a 28psi twin port actuator,
-34?? 14psi? PMSL.
I run a 24psi actuator now!!
Don't ask - I don't know
I can't really afford a new one at the minute because I need to buy some other bits too
-34?? 14psi? PMSL.
Originally Posted by JTECHSAFF
so would i benift from fitting a -34 to my saff? i run 33 psi with a -31 at the mo, was a bit sceptical of putting that much tension on it tbh
Testing the future
don't forget that in between the compressor and the actuator on most cossies is an SEM valve that has a restriction in it to create a pressure drop, so it depends on how that is ported as to what the actuator will do in reality
wowk
30-03-2021 07:49 PM
SMILER258
28-09-2015 09:04 AM
