Some new R&B Products....
£175 + delivery.
1 x Threaded in one end - v piece standard on 2 wd and Escort Cosworth for having oil pressure switch and oil pressure sender out of block - £15 + delivery.
1 x Threaded in both ends - is standard on 2wd Cosworth (no longer available from Ford) to have oil feed pipe to turbo and oil pressure sender on inlet side of block close to dipstick - £15 + delivery.
M12 Lamda nut for standard lamda on Cosworth when changing turbo to one without lamda mounting on, for mounting on down pipe. Made in stainless-steel - £6 + delivery.
M18 Lamda nut for wide-band lamda sensor when mapping with blanking bolt and washer. For mounting on down pipe. Made from stainless
steel £13 + delivery.
Short shift for Cosworth 4x4 MT75. Replaces standard unit and made of good quality steel, with shortened throw, but not as much as B&M (to protect syncros) - £35 + delivery.
Aluminium fuel rail diameter inside 17.5 mm threaded for -AN 8, fits where standard fuel rail fits (on all plenums) - adjustable height to suit all injector types - £160 + delivery. Also possible to buy unmachined in free lenghts of undrilled fuelrail (only a hole through it - to enable maching for siamese WRC injectors) for £6.50 for each 10cm + delivery
80 mm, 110 mm & 160 mm long actuator rod made from good machine steel then anodised - £15 + delivery.
I needed one of those fucking longer actuator arm things the other day and didnt know where to get one, luckily doug stirling came to the rescue
All look nicely made bits of kit there mike, is it all swedish stuff you are reselling again or is some of it actually made for R&B exclusively?
Originally Posted by RWD_cossie_wil
top one looks like a rear diff cover plate but I suspect it's not
Chip,
These items are the Swedish stuff . Although I have a few hard to get items being made exclusively in the UK, but am still waiting for these....
Originally Posted by Dave Henshall
looks like a 4x4 front diff cover - is it toughter than the std one..?
Re: Some new R&B Products....
[quote="Mike Rainbird"]
are those aluminium?
High grade stainless-steel .
thank fook for that, i could just imagine how many people would have snapped them off in the block whilst tightening them up
btw.. nice carpet, was it cheap?
bling rear diff cover - so everyone can see you've cleaned your diff!
floo floo valves that screw into the fuel rail.
Sump nut - again bling so people can see just how bufty your car really is.
Banjo - not the string type though.
Fuel rail - to replace that nasty standard item.
non-threaded bonnent pins - really useful
Am I right?
Am I right?
Am I right?
Am I right?
for example:
http://www.engineersedge.com/materia.../toughness.htm
you know things like that in your line of businees mike
Am I right?
Am I right?
Yup... hence I don't strengthen things with aluminium
Am I right?
Am I right?
Am I right?
Am I right?
Stronger or Tougher mike?
Think carefully
Stop trying to be clever with semantics - you both know EXACTLY what I mean . Bastards . Okay, how about, torsional rigidity over the standard item is improved ten fold - satisfied?
Im not satisfied without seeing test data to prove your claims no
Seriously though, looks good mike, what are the prices of each item, as thats going to be the next question asked no doubt!
Originally Posted by Paul Ripley
Front diff cover
Oil pressure sender blocks
MT75 quick shift
Longer actuator arms
Fuel rail
stumped by the two cap and bolt things thou
MT75 quick shift
Fuel rail
The items you are stumped on are stainless-steel lamda bosses, the big one is the 18mm wide band and comes with the machined boss to weld on to the down pipe, and the nut then unscrews to allow fitment of this. The smaller one is to move the narrow band item to the down-pipe if this is to be retained and the turbo no longer supports this... .
[quote="martin-reyland"]
Originally Posted by Franco
The prices on your website yet Mike?
As to the "carpet" it is actually one of Sunlight's finest mats - the carpet underneath is FAR worse .
