Fitting a dimmer switch!!!
Old Dec 5, 2006 | 03:16 PM
gwynny's Avatar
gwynny
Default Fitting a dimmer switch!!!
Right I bought a dimmer switch from B&Q earlier and I cant get the basturd to work.
the existing switch has a com terminal and L1 terminal.
But the new one has Load and live. I've tried both way's round and neither work!!!!!
Whats going on!!!
Old Dec 5, 2006 | 03:27 PM
vroomtshh's Avatar
vroomtshh
Have you tried pushing the switch in? I'm not being funny, but when i fitted mine, i turned it a few times and nothing happened, then i realised you need to push it in first
Old Dec 5, 2006 | 03:40 PM
gwynny's Avatar
gwynny
its not a rotary one its one of the touch sensitive badboys! still dont wanna work tho!
Old Dec 5, 2006 | 03:51 PM
Cowboi's Avatar
Cowboi
sounds to be broken tbh.
u have turned the power back on havnt you?
try putting both the cables in one side of the switch and turn the power on just to make sure the bulb aint blown or anything.
i dunno about the touch senstive fancy ones, but in general they r pretty much a variable resistor.
so if the lamp comes on when u put the 2 cables together and not through the switch, after reading the instructions to make sure u aint gotta do anything special i'd be going back to b&q for a new one
Old Dec 5, 2006 | 03:52 PM
richj's Avatar
richj
Com = Live
L1 = Load
If that doesnt work the unit is fucked, you might have blown it by wiring
it in reverse the first time !
Old Dec 5, 2006 | 03:56 PM
gwynny's Avatar
gwynny
just read the writing on the unit and it says it is to be used with a master unit or summit, so basically its the wrong switch!!!
Back to B&Q then!
Cosnada
Aug 27, 2015 09:15 AM
mrmann
Aug 20, 2015 11:24 PM
Perfmr2
Aug 6, 2015 07:30 AM
Caddyshack
15
Aug 4, 2015 08:50 AM
