bleed valve fitting
Old Dec 5, 2006 | 12:54 PM
rsguy's Avatar
rsguy
Default bleed valve fitting
just a quick question,
i want to setup my boost on my car as ive just bought a boost gauge but instead of getting underneth everytime i want to adjust the waistage arm im fitting a bleed valve.
when fitting a bleed valve, i know one pipe goes to turbo compressor houseing and other to waistgate, but what i want to know is when you fit a bleed vlave do i have to turn the waistgate rod all the way clockwize towards the atuator so theres no thread left ?
thankyou
Old Dec 5, 2006 | 01:00 PM
Stu @ M Developments's Avatar
PassionFords Creator
Before we tell you how to add boost, please tell us how your going to supply the extra fuel for that boost.
If you cannot tell us, then please step away from teh spanners before you have a very unmerry Xmas...
Old Dec 5, 2006 | 01:02 PM
ballin's Avatar
ballin
no you dont mate.
set the actuator to half-moon preload then use the bleed valve to bleed off until you hit the boost you require. (depending on amount of boost and actuator used, but generally,..)
with the correct fueling of course
Old Dec 5, 2006 | 01:04 PM
rsguy's Avatar
rsguy
the car is running megasquirt managment mate,
think im safe about overboosting, as ive set the overboost in megatune.
also think its currently running 7 psi so im only going to adjust it for extra 3 psi which is 10 psi mate.
ballin do u mean just set the rod half way?
Old Dec 5, 2006 | 01:05 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Nasty nasty things, bleed valves. Only good IF you know what you are doing
Old Dec 5, 2006 | 01:06 PM
Cool, in that case do exactly as Ballin explained mate. Preload by 3-6mm Max ideally and bleed the rest.
Old Dec 5, 2006 | 01:09 PM
rsguy's Avatar
rsguy
im useless at psi maths lol so does anyone know what 10 psi is in kpa ? cars is setup for 145 kpa overboost which i think is 7 psi am i right?
why do people say they are nasty ? all depends on what you do with them, ok i know most people get boost happy and turn the screw under bonnet, without any overboost protection enabled, causeing overboost and spikes,
but if used correctly then they are ok, megasquirt has the option for overboosting which is a good thing as it cuts out spark or fuel if boost hits pre overboost level.
Old Dec 5, 2006 | 01:10 PM
Porkie's Avatar
Porkie
Good enough for Martin to set all the old Cossie records on!
Old Dec 5, 2006 | 01:13 PM
CossieRich's Avatar
CossieRich
Lee,
I said they are only good IF you know what you are doing. I've heard that Martin knows a thing or 2 about turbo'd engines and how to set the boost
bud-weis's Avatar
bud-weis
Football Cwazy
as said,the problem is that people can mess with them too easily!!
an amal valve is essentially the same thing anyway!
Old Dec 5, 2006 | 02:24 PM
Avinitlarge's Avatar
Avinitlarge
6.9kpa is roughly 1 psi
Old Dec 5, 2006 | 03:23 PM
rsguy's Avatar
rsguy
so what would 10 psi boost be in kpa mate?
just fitted gauge, im gona take it out in a bit to try it, noticed its in the 20 while ideling is that normal.
Old Dec 5, 2006 | 03:32 PM
ballin's Avatar
ballin
6.9 * 10 = 69kpa mate
Old Dec 5, 2006 | 04:06 PM
Avinitlarge
plus about 95 or what ever the kpa gauge says when the engine isnt running
Old Dec 5, 2006 | 04:22 PM
rsguy's Avatar
rsguy
eah its on 0 when engines off, it drops to 20 when ideling.
will let you know later whats its boosting however i fitted a bleed valve so i might need to make adjustments
69kpa = 10 psi
140 kpa = 5 psi ?
so the lower the kpa the higher the boost?
that right? as my car origanally was set for overboost at 145 kpa and i was hitting that and it dident seem that fast.
Old Dec 5, 2006 | 04:27 PM
Moonie's Avatar
Moonie
Old Dec 6, 2006 | 02:20 AM
rsguy's Avatar
rsguy
why the picture mate, i dont plan on blowing it up lol.
i fitted the gauge its hitting 5 psi then overboost kicks guess im going to have to adjust the overboost setting for 10 psi.
anyone esle running this psi? as im thinking my bov is not working because not enough pressure at only 5 psi.
Old Dec 6, 2006 | 02:50 PM
Avinitlarge
And again,
6.9kpa = 1PSI
about 95kpa with the enigine off
So 6.9 X 5 = 34.6 + 95 = 129.5
So lets call 5 psi = 130kpa
blackbeautyzetec
Aug 29, 2015 02:11 PM
jay030787
Aug 17, 2015 06:16 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 16, 2015 08:38 AM
rsstav
Aug 11, 2015 04:22 AM
Red_bull
Aug 9, 2015 08:34 AM
