cossies as track cars
i see a lot of you track your cossies
i want to get into doing a few but have been warned off by tuners
saying that you cant just take your cossie out on a track its a road car not a race car and you'll kill it straight away
they said you need to spend thousands on it before even taking on a track
with oil coolers for everying, full rebuilt, wire rung block, etc etc
what mods have you all done to yours to be able to track it?
you'd need a big wing sump idealy.
if you have a tired engine then its probably not best advisable to track it.
remember on a track you're at WOT an awful lot, and revving the engine.
RPMS can kill engines
mine is just a average stage 3 4x4 & have done 4 trackdays since I've owned it with no problems apart from a knackered gearbox ( it was whining before I smashed it though )
just make sure the suspension, brakes & tyres are up to the job & the car is properly serviced.
if it has any running issues at all do not take it on the track as u will be asking for trouble
they may have warned you off not because of the car it could be your driving
and track days are alot of fun UNTIL they go wrong..then it seems like a silly idea if you crash it etc
A healthy Standard cossie would take a trackday no problems engine wise in my opinion. You would not need a bing wing sump unless you are running slicks and an oil cooler unless you start seeing oil temps of 110++++
The standard BRAKES would be the biggest problem in my opinion.
A well maintained Stage 3 Cossie is a reliable and awesome trackcar in my opinion.
The problems come when people take tired and bodged, and poorly maintained Cossies on track.
Did Someone Mention TUV
Im sure there are a lot of people like me who havent and cant afford thousands of pounds to spend on their cossie just to get it properly sorted for the track. So im going to make sure its the best i can get it, fresh oil, filter, brake pads and discs inpsected and re-newed if needed and plenty of tread on the tyres. If it turns into a nightmare halfway through the seesion i shall simply pull off and let her cool down and try again. I havent got big brakes either. Just uprated standard ones
Caraholic
Re: cossies as track cars
You don't NEED an oil-cooler below 400bhp or even big brakes if the power is no more than stage 1 (although the braking will need to be in it's prime with racing fluid, braided hoses and decent pads).
A nice reliable (smallish) budget track Cosworth would be:
Stage 1, 4x4 intercooler, 17" wheels, good tyres, Konis, shims on rear, poly-bushed all round, Castrol SRF fluid, braided hoses, Ferodo DS2500s, strut braces front and rear, harnesses for driver (stops you rolling round and helps driving).
Anything you can stretch to regarding improving the brakes will be money better spent than giving the car more power . Stage 1 is also dead reliable . If you want to have fun, rather than going fast, keep the standard sized wheels and tyres .
You need to be aware that there is no such thing as a cheap track day - it WILL cost you at least £500 (pads, tyres, fuel, entry costs, travelling etc).
My cossie is nothing specal i've put a 6 point roll cage in My Engine is off Paul @ north Yorks breas and will be set up to st3 with T34 and i have a Big wing sump tp go on I belive thats Good enough Or tho my braes could do with uprating ,
I do have some other bits that i have picked up like Hydlic Hand break FOAM FILLED FUEL TANK (Standard Cossie tank removed from a race/rally car that ATM Sport broke) Braided fuel line on its way next week Im putting the Batery in the back in a box and i dare say some other bits as i go
done about 7 trackdays now in mine,well maintanenced and keep boost levels clever ,but like porkies says brakes are a must,coilovers and tyres will soon follow
cheers mike & everyone else who posted
so i dont really need to do anything out of the ordinary by the sounds of things
i've only had the car 2 months now so not done too much to it as yet, got konis, & NMS gunship conv. so far and sorted a few issues with it
think i'll see how it runs for the next few months, make sure its got a good engine n is reliable and take it from there
n hopefully be joining you n a few trackdays mid next year
Super Moderator
Originally Posted by JayCos
and then came eagle standard clutch, head gasket 110k on the clock 24 psi yyyeeeeehhaaarrr
standard headgasket on 24psi ... i have had a few people tell me you can't oh well
rear road tyres are 4 years old
front road tyres have done 6 track days and are a bit shot now
track days on a budget
You don't need to go mad to have a riot on track.
Preperation plays a large part. SO check all the major components over and check your fluid levels.
I'm a complete track convert
The one thing missing from any of the above lists is CHECK YOUR WHEEL BEARINGS !! Std cosworth wheel bearings may be up to the job of a roadcar but expire very quickly on a track , check , adjust and re-grease , if notchy then Replace !
Enjoy .
Enjoy .
Football Cwazy
you sound like you have been speaking to Karl
he also advised me to fit ;
Big Wing sump
oil cooler
diff and box coolers
couple of grands worth of stuff easy there,i'm running about 450bhp though so i suppose a big wing sump is the minimum i should do,and just not do too many laps at a time flat out, apparently the diff/gearbox oil goes like soot if it gets thrashed for too long without a cooler
Big Wing sump
oil cooler
Big Wing sump
oil cooler
Big Wing sump
oil cooler
Caraholic
Big Wing sump
oil cooler
Big Wing sump
oil cooler
Enjoy .
Enjoy .
and spot on advice about the baffle and the oil and gearbox coolers!!!
be sensible on track is the biggest thing you can do...
limit sessions to 5 laps at a time as to keep temps at sensible levels.
dont know how many cossies i saw with popped expansion tanks caps at national day..
RIB1122
13-08-2015 09:09 PM
track.focus'd
12-08-2015 05:53 PM
Versus_Creations
24
05-08-2015 09:32 PM
