fuelling advice
fuelling advice
put a wideband on the binliner and on boost it is in the 11s but on idle it is around 15-14.5 but gradually gets richer and richer every few seconds or so until after around 3 minutes it will be in the mid to early 12s. This shouldnt happen should it,so what would cause it to richen up on idle like it does? std lambda??
so it dropping into the early 12s on idle is ok and wont be borewashing etc? if i lean it off on the safc it just makes it mega lean on idle the next time i stop until its sat a few mins and richened back up
its the standard ecu m8 with a air fuel comp which manipulates the afm signal. crude idea but helps cure the overfuelling stage 1 mods cause,so no i havnt, plugged lappy in and ran some sofware which reported no sensor issues etc but other than that,the wideband and egt gauge with knock sensor its all ive got to help get it right. How dangerous is running lean on idle??
mk3ste
17-10-2021 11:09 AM
Mc5506
05-10-2015 10:57 PM
rsguy
44
29-09-2015 04:29 PM
