Fifa 07 On PC
Fifa 07 On PC
I've got it, playing it using a controller. I don't know what the trick stick/button is. When I set up the controller, a trick button wasn't mentioned? Is is the same button as one of the others, if so which one?
Also, just won the Championship as Cardiff City but it seems all I can do is save the game, there isn't an option to play in the Premiership? Is that normal that you can only play one season with a club?
ive got it for the 360, and as of yet, ive found no trick button, but you should be able to play longer than 1 season, i played a full season in manager mode as liverpool, then moved onto the next season no problem. but i suppose the pc version could be different to the 360
Dal_
06-12-2010 03:11 PM
