mondy 4x4
mondy 4x4
I know this has probably been covered a million times, but I dont care!
How much power do you all think mondy 4x4 running gear can take? ( gearbox, diff and transfer box) I want to 4x4 my focus and this looks the easiest route without chopping the bulkhead and the floorpan out.
Or had anyone done it?
Ta in advance
Ta in advance
im sure that'd be fine for the std 2.0ltr engine but i'm not sure what power the running gear you mention would take?
It might be worth exploring the use of mitsy evo running gear, im sure there are a few breakers around. The engine position is more similar to a fwd car and its also very strong... one posibility anyway
Originally Posted by Davey C
My welding skills are basic mate to say to very least. I'm not chopping my floor pan out! I'm 99% sure that the mondy stuff will fit with only my spare wheels well chopped out. ( and the exhaust re routed. )
I'm sure someones done this a few years ago, painted it cadburys purple. Was on the cover of Fast Ford, but I cant find any info anywhere
Its had Fiat Coupe management on it or summat daft
mondy 4x4 use the same sort of running gear as rs2K 4x4 iirc good because it utilises the transverse engine position but need to uprate transfer box i believe to take over 250bhp. but as said evo running gear can be made to fit
Originally Posted by Cawood
speak to martin @ reyland
he did a 4x4 mondy cossie, quality motor did a 178mph top speed run IIRC
not the tranverse zetec 4x4 gear.
i tought that purple focus had cosworth management
this has got me thinking , i wonder how hard it would be to convert my st24 (mk2) mondy to 4wd or even rear , i guessing that the problem would be with the gearbox and transfer box as the 4wd was only on a 2.0 zetec
You sure about that?
i thought the reyland mondeo cosworth was transverse fwd?
re: st24 4x4, jaguar x-type, transverse 2.5 v6 4wd using a mondeo floorpan.
the reyland mondeo is actually 4wd and as to the evo gear
DJM motorsport have modified a cosworth engine to take
4wd and have mounted it transversly so may want to speak to them
djm-motorsport.co.uk
Why would anyone want to build a 500bhp FWD car??!?!?! never understood that!
Ive a customer bought a Hewland 6 speed sequential 4wd gearbox from me last year, apparently its now in a Focus that runs a Zetec turbo engine i do have another box and a couple of diffs if anyones feeling brave , lol .
i stand corrected then.. sure someone on here had a fwd yb mondeo?
what a pointless idea, the YB is crap for fwd imho, i would sooner turbo a zetec!
DEYTUKURJERBS
But on that note, what DO 20Vs run?
(Going a bit off topic, but what managment did Integrales run? Did evos run P8? Did 16v's ran L8? Ad ive never heard owt about what 8valves ran...)
Engine Machinist
i just picked up a complete ecu and wiring loom from a lancia dedra (not delta, before anybody tries to correct me,) intergrale for a bargain price! will probably be making its way onto a metro
so fiat coupe's ran p8... hmm... i've got an idea!
Davey C - if you really want to do this and have over 280 bhp you will need the transfer box uprated as there was a 300BHP RS2000 that was featured in fast ford and performance ford and he had the transfer uprated and no issues - i think he got it done at cts and he also had the oil capacity increased at the same time
Mark
yeah it wont be simple but you should check out the other projects on this forum as there are a few people doing RWD and 4WD conversions
and ask them if you are unsure and check some engineering books
the simplest way i see it would be just to use the floorpan out of the sierra
and leave the engine bay area as standard so no grafting together bulkheads etc. and this would mean the mounting points would already be on the floorpan from the sierra so minimum fabrication
07-10-2015 12:56 PM
