Driveshaft bloody popped out again
yeh mate reckon most people put xr 4x4 shafts in the front on lowered suspension , we put them in Bigad4x4's they definately do the trick mate they're an inch longer, and as they say am inch makes all the difference!!
I would personally check the driver's side engine mount first. This is likely to be fucked and causing the problems . Standard drive-shafts are NOT an issue, unless you are running stupid camber or the car is "slammed" .
Caraholic
i wouldnt say the xr shafts are to long
they dont need a circlip to hold them in place either which is better as its quicker and easier to change
loads of people run them with out failures
and is a cheap mod thats well worth doing once engine mounts are sorted
especially if your car is low
1st to 200 without NOS
xr shafts are too long +14mm. You need about +5-7mm and a new circlip groove cut into the hardened shaft
Caraholic
