A question about YB heads and valve size FAO Stu Chip etc
Visitor from the Darkside
Is there any point in changing the size of valves of they are getting replaced anyway. I am probs going to have to change the valves in my car and wondered if it is worth putting bigger ones in. My car runs on a closed loop stage 3 on a saff 4x4. What other changes would I have to make if any and is it worth doing???
Thanks for any replies.
Graham
Graham
Thanks for that. I wondered if making them bigger would make it worse.
At least some of them will need to be changed as I suspect some are not as straight as they should be!!
Waiting to see what happens when the head is removed. Are aftermarket ones any good as I can get them at a good price from the states???
Graham
Graham
Graham
Graham
It depends on which aftermarket ones.
Some are awesome (nemonic 80 etc) others arent just cheap crap.
Personally i would just use secondhand standard ones to replace the few that you need to.
Can remember the exact name of those ones. It started with an S and they were coming from USA. He said they were Teflon coated. I wont use second hand ones as it is false economy. The head was refurbshed 1500 miles ago so barring any damage should be OK.
Graham
Graham
CabrioTurbo
01-08-2015 11:04 AM
