XP problem, Help!
Old Nov 3, 2006 | 10:04 PM
PhilM's Avatar
PhilM
PassionBMW.com Member
Default XP problem, Help!
Evening guys,
Was wondering if anyone could help with this little problem I have on a laptop.
Essentially someone turned it off, whilst it was installing windows updates (during shutdown - the one that says, iinstalling windows updates, donot switch your pc off ).
Anyway, now, it doesnt boot, get the XP splash screen come up, it'll stay loading for a few seconds then the machine just reboots.
If I hold F8 and select start in safemode during boot, safemode does the same.
Is there anyway I can use a bootable cd to run a system restore? I don't want to format it with XP again as it'll lose a load of work, and will probably screw up the warrenty (its only a few weeks old!)
Old Nov 3, 2006 | 10:11 PM
Rick's Avatar
Rick
boot from XP cd, then choose repair. Won't touch any user files.
Old Nov 3, 2006 | 10:12 PM
fezz's Avatar
fezz
have u tried the last known good configuration
Old Nov 3, 2006 | 10:13 PM
PhilM's Avatar
PhilM
Cheers Rick...
Does it matter if the installation is XP Home and my CD is Pro?
Old Nov 3, 2006 | 10:15 PM
PhilM's Avatar
PhilM
Yep Fazz, tried that, no joy...
Old Nov 3, 2006 | 10:28 PM
Rick's Avatar
Rick
No, it shouldn't. You will need the serial of the copy you are installing.
Old Nov 3, 2006 | 10:29 PM
JohnnyB's Avatar
JohnnyB
If I had the same problem at work on a laptop I would rebuld it.
if some files were needed of it I would use ERD commander and take them off
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
