Q for secs
Q for secs
My secs monitor has the ability to read peak boost up to 33psi, which is exactly what i run, but it will only read up to about 29, i take it thats because of the range of the map sensor? but o only have the choice of 2, 2.5 0r 3 bar map sensors
Any ideas if/how i can get it to read full pressure?
More worryingly than the SECS monitor seeing it, how are you fuelling for 33psi on a 2 bar? Or are you just chucking in 33psi worth of fuel at anything over 29 and excepting it running a little rich at 30/31/32 psi?
You are right, it is the limit of the MAP sensor.
You could put a bigger sensor on JUST for the monitor as there is
an upgrade to fit a 5 bar sensor (45 psi)
Sensor is about Ł100 ish (from others)
Upgrade is Ł10
Upgrade is Ł10
chip-3door,
That is exactly how all chips over 2.0 bar work on Weber ,
I.E they fuel for your maximum boost at >2.0 bar
So if you have 2.5 bar then you get teh same fuel at 2.0 bar
SECS, yeah i know mate, and other ECUs too for that matter, just wasnt sure if he was doing that or if in this instance he had a seperate MAP sensor for the ECU and for the Monitor and the ECU one was 5 bar, if it was then i was going to suggest the upgrade to allow him to select 5 bar
88_WRC_Replica
22-07-2004 03:03 AM
