quick CO question
Old Nov 2, 2006 | 10:26 AM
gingeRS's Avatar
gingeRS
Default quick CO question
what should i set the CO to? on an exhaust analyser.
saff 4x4 dk greens stg3
i need to know what to set it to at idle, turned it down for the mot, as have idle problems.
also should i check it at another engine speed??
in theory if the engine is fully warmed, it shouldnt matter whether the iscv is plugged in. and does the throttle adjustment screw affect CO?
cheers guys
R
Old Nov 2, 2006 | 10:45 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Trouble with adjusting it is the fuel will be adjusted over the entire map..
Old Nov 2, 2006 | 10:47 AM
JTECH James's Avatar
JTECH James
Passion for Fords!
yeah its a global fuel adjuster not just a idle co trim
when up to temp the iscv should have no effect on idle speed as it should be shut.
Old Nov 2, 2006 | 10:52 AM
Paul_RS's Avatar
Paul_RS
Is that the screw on the ecu? It doesn't affect the whole map, its only the idle. We proved this a few weeks ago on my friends stage 3 4x4 saph.
Old Nov 2, 2006 | 10:55 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Screw must be 'screwed' then
Old Nov 2, 2006 | 10:57 AM
gingeRS's Avatar
gingeRS
this is what i though. it just affectis the fuelling at idle.
the fuelling over the entire map as on the ECU itself
Old Nov 2, 2006 | 10:59 AM
bud-weis's Avatar
bud-weis
Football Cwazy
Afraid not pal, it adjusts the lot
Old Nov 2, 2006 | 11:18 AM
gingeRS's Avatar
gingeRS
how can you map for all engine speed load conditions, with just one screw.
and by that theory, if you have the 'correct' fuelling at idle, you will have the correct fuelling over the whole rev range
Old Nov 2, 2006 | 11:20 AM
Paul_RS's Avatar
Paul_RS
nope, it affected idle, not the rest of the rev range?
Old Nov 2, 2006 | 11:46 AM
bud-weis's Avatar
bud-weis
Football Cwazy
presumably you set the screw for your base idle,then adjust the values within the map for all conditions,i'm sure Stu or somebody will explain it better,but that pot is normally fitted with a tamper proof plug,presumably ford didn't want people messing with it
Old Nov 2, 2006 | 11:54 AM
Stu @ M Developments's Avatar
PassionFords Creator
The screw is what we call a global modifier in as much as it adds a percentage to the entire fuel map.
If your engine is just borderline safe on boost, leaning the CO can and will destroy teh engine when flat out. The correct base position is in teh region of 5 turns clockwise and 2 turns anticlockwise to put you back in teh ballpark, but this is of course dependant on MANY MANY factors such as heads, cams, sensors, fuel pressure etc etc...
Old Nov 2, 2006 | 12:18 PM
gingeRS's Avatar
gingeRS
If your engine is just borderline safe on boost, leaning the CO can and will destroy the engine when flat out. The correct base position is in the region of 5 turns clockwise and 2 turns anticlockwise to put you back in the ballpark, but this is of course dependant on MANY MANY factors such as heads, cams, sensors, fuel pressure etc etc...
thats what i thought, at the minute i'm not driving my car on boost (def not flat out) as it was adjusted down for the mot and other reasons
its all standard, head cams, all sensors work etc.
so the car has to be adjusted on a rolling road? or is the 3% @ idle a ball park for CO? i have access to an analyser but cant do it live.......as such
Old Nov 2, 2006 | 12:21 PM
Ask teh mapper of teh chip what the co should be, then set it. Job done.
Old Nov 2, 2006 | 12:31 PM
gingeRS's Avatar
gingeRS
looks like its time to call power engineering then
i can set this CO at idle then?
Old Nov 2, 2006 | 02:14 PM
gingeRS's Avatar
gingeRS
just spoke to power engineering and they said this screw is 'only for idle' and they just adjust it till the engine is 'happy' sounds and runs smooth.
they said the majority of the fuelling should be governed by the ECU map, map sensor and fuel pressure.
it may take a while to get this, and the iscv - high idle issues sorted
Old Nov 2, 2006 | 02:36 PM
LOL. Now you have a problem dont you. ROFLOL.
Old Nov 2, 2006 | 03:52 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
as said, adjusting the screw will alter the mixture over all the rev range.take it to somebody who knows what there doing.try stu.
Old Nov 2, 2006 | 07:39 PM
gingeRS's Avatar
gingeRS
OMG......
i followed stu's instructions, 5 turns clock...2 turns anticlock. took me a while to figure that it is a potentiometer...
i was turning the thing for bloody ages with the engine off to get it in a closed position
also following SECS and Richm's instructions to check the tps. and guess what.......
it now runs....sweet....iscv is working as it should be!
just gotta get the co checked before i give it a bootfull.
tankybaby66
Feb 6, 2016 02:24 PM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
