Tech Question??
Old Oct 28, 2006 | 09:38 PM
GTechR's Avatar
GTechR
Default Tech Question??
Sorry it's not in the tech section but 9 out of 10 times I never get an answer thare
Anyway...I have an idea formulating in my head and I wanna run an I4 on carbs and no ECU, could I do it the same way as you can with a zetec using the HCS Fiesta stuff?
Old Oct 29, 2006 | 12:31 AM
PhilM's Avatar
PhilM
PassionBMW.com Member
Should do, run the CPS sensor into it, the coilpack, and I imagine (but can't remember - been a long time since I had my Mk5), a vacuum module for the advance.
Old Oct 29, 2006 | 06:43 AM
GTechR's Avatar
GTechR
Nice one... cheers matey!!
Old Oct 29, 2006 | 08:01 AM
GARETH T's Avatar
GARETH T
why no ecu though?
they are so cheap nowadays,,, and you will get the best from the engine and not a compromise
magajolt from alex f on here would be perfect
Old Oct 29, 2006 | 08:09 AM
GTechR's Avatar
GTechR
Originally Posted by GARETH T
why no ecu though?
I totally appreciate, what your saying mate, and yes in an ideal world that would be my first and only choice. But I personally dont have the first clue with regards to mapping, and as I understand it, most tuners wont touch the likes of Megajolt or Megasquirt, and of the few that do the cost of mapping would seriously dint my budget
Old Oct 29, 2006 | 08:40 AM
GARETH T's Avatar
GARETH T
im sure if you bought the unit from alex,, he would do you a cracking deal on mapping it
Old Oct 29, 2006 | 07:43 PM
GTechR's Avatar
GTechR
Cheers for the pointer mate, I may have a word if i decide to go down that route
Old Oct 29, 2006 | 09:21 PM
AlexF's Avatar
AlexF
I can supply a base map and tweek it for you when its up and running
MegaJolt is really easy to setup - any mapper/dyno place will be able to do it for you if your not local....
Alex
Old Oct 29, 2006 | 09:26 PM
GTechR's Avatar
GTechR
Alex
Fair play mate, i'll keep you in mind, still unsure which way to go.
Old Oct 30, 2006 | 07:52 AM
GARETH T's Avatar
GARETH T
if your going o an ecu based ignition, you might aswell go for throttle bodys, they cost the same as carbs
Old Oct 30, 2006 | 08:11 AM
Trying to get a really acurate advance curve on a dizzy is a LOT harder than it is on megajolt or another ECU, if you cant map it yourself, then you can be damn sure you will be utterly fucked when it comes to bob weights and springs and stops to try and do the same thing!
Old Oct 30, 2006 | 02:12 PM
GTechR's Avatar
GTechR
Already running carbs mate...
Old Dec 3, 2006 | 04:08 PM
AlexF's Avatar
AlexF
carbs are evil
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
