YB rattle.....HELP
YB rattle.....HELP
...after putting new lifters in its totally quiet....BUT when i drive it under load it rattles slightly..sounds just like an exhaust type rasp/rattle (may even be,not checked that area yet)..past 3k revs it dissapears...its annoying...is it anything to be concerned about?
As nutter, i had a big end bearing go - and i would have bet money it was something at the top, as it was a a light tap.
Oil pressure will be good if it's just one bearing - the oil pump just works harder to maintain the releif valve pressure. This doesn't mean all your bearings are getting pressure though.
..wouldnt a big end noise get worse the higher the rpm?..this dissapears after about 2500rpm?...i can get it to do it stationary too from when its idle it only does it a part throtlle rev and certainly sounds exhaust cam area?
