cos engine into standard saff
escort mk4 cossy 4x4
what parts would i need to fit a cosworth 4x4 engine into a standard sierra? its only a short term idea so i can run in the new engine,while the escos is having the body work sorted.is there any model its easier to fit it in?
No point, running in takes 100 miles or so. Just warm it up, then drive it hard but smoothly making sure the engine doesn't labour and you use most of the rev range.
running in a good engine should be 1000 miles+ a bloke by me ragged his focus rs from new with bad results,his car was fukkkked so run it in for 1500miles for best results i sound like delia smith!
if its 4wd then your best of buying a 2.9xr
that way you dont have to change the rear diffs as there the same
you dont have to modify the tunnel unless your using the skyline box
and the front chassis legs dont have to be modded
other than that if you use the std box then everything will drop straight in no messing
the loom is easy aswell as it will mainly plug up bar a couple of wires
obviously tank and fuel pump change maybe duno what the 2.9 internal pump will flow
really easy conversion though if you have a 4wd shell unless you dont mind making the mods to the std 2wd shell
Originally Posted by costina
Drop ur engine and box into a xr 4x4 job done
buts yes you can just change the rear diff to a cos one and job done
eveything will just bolt in as it should
to fit cosy brakes you need to use the hubs front and rear aswell
Guest
Posts: n/a
My old mans got a 2.9 XR4x4 he's owned since about 1991, its just garaged now as he doesnt use it, its in pretty good nick, just wants rid of it now as he's selling the house and wants to put the jag in the garage over winter, let me know if its any use to you, he wont want hardly anything for it, maybe Ł150 at most, I put it thorugh its last MOT and it needed an an exhaust and the handbrake cable adjusting probably do with a new cable now though as its adjusted right up but it struggles to hold it.
Live long and prosper!!
rog
04-09-2015 12:10 PM
track.focus'd
12-08-2015 05:53 PM
