ALS on Cossie's
#126
Originally Posted by GARETH T
fitted,,, does need some tweeking though
it does work,,, but it does like lifting under low pressures,,,
this is a few ways i can help this though
#130
the "slug" inside the holder is too long (i made it this way so i can make it shorter) when this is shorter it will have greater lift energy
also,, if i drill a few small holes in the face of the disk,, this will reduce differential pressures (of cause i would have to close my idle bypass up to gain my 1000 rpm idle again)
what you think mike?
#133
fudgeass
alot
Mike Rainbird
i cant be 100% its going to work,,, but it is mk1
and an engineer who never made mistake,,,,, never made anything
and how much would such a thing cost, say for instance a fast ford project car wanted to use such a thing and you would get some very good advertising out of it lol
Mike Rainbird
If it works then cool
#134
Nice design.....
I think 25W is still a little low....the ultimate way would be twin wound coil...high wattage to lift it then low to hold it.....
Looks good though pal....just dont like the bolt in the end....preferred to make the valve as a whole.....
#139
the original
sadly mate,, i havent got enough time to make stuff like this for people
Stu @ M Developments
thanks stu,, means alot coming from you
#141
Originally Posted by turbospud
what are the costs involved in fitting als to a 2wd
247 shafted turbo
an als valve
and a small bit of wiring
about 1500 quid if you do it on a budget
#144
Passionford Thread Killer
247 shafted turbo
an als valve
#147
Originally Posted by sibster
Most proper maram shafted ALS turbo's are T34's as these are the variety used on rally cars....
Maram shafts are getting rare though....
Saying that if for example a GT costs more than a maram shafted T34(a less advanced turbo),
is there any point in spending the extra on a GT (which to my understanding will be a more advanced faster spooling turbo) when your using ALS anyway?
Though I guess it also depends on the rest of the engine , to what state of tune it is, using what components ect. ?
#149
Originally Posted by Stu @ M Developments
ALS will be available on the L8 very very soon too.
or should that be as it something else to spend my pennies on
#151
#155
Rally nut
Russ Payne
25-09-2015 08:29 PM
