rc engine set ups...
Old Oct 17, 2006 | 10:00 PM
wirralphil's Avatar
wirralphil
Default rc engine set ups...
for some reason the engine in my rc car cuts out after 10secs when i pull start it again it fires up perfect then dies.
does any one know how to set up the carb on these???
on the car there is a screw for the opening of the barrel, a small srew through the centre of the barrel and a brass screw next to fuel pipe if this helps.
Old Oct 17, 2006 | 10:06 PM
TrevCannon's Avatar
TrevCannon
PLEASE W/E u do DONT TOUCH THE SCREW THROUGH THE MIDDLE OF CARB because it will need run proper ever again
If you have you have to take it to your local hobby shop for a carb service
Rigth lil screw with spring is the idle screw & the big one in a sleeve is the high speed fuel mix screw, the one go's through the carb is the low speed fuel mix "wich should be never touched"
What car is it?
Old Oct 17, 2006 | 10:09 PM
wirralphil's Avatar
wirralphil
it's a cen gx01 with a .16 engine.
had it running before for around 2mins then cut out.
Old Oct 17, 2006 | 10:22 PM
TrevCannon's Avatar
TrevCannon
You mean one of those?
Old Oct 17, 2006 | 10:25 PM
wirralphil's Avatar
wirralphil
thats the one but i have the one with the the .16 engine, power pipe and 2speed gearbox. not the .12
(oh and i have a red anodised chassis if you want one)
Old Oct 17, 2006 | 10:56 PM
TrevCannon's Avatar
TrevCannon
http://www.cenracing.com/downloads/E...oc%20NT-16.doc
Basically the same engine hope that helps...
Old Oct 17, 2006 | 11:00 PM
wirralphil's Avatar
wirralphil
nice one. will have a fiddle in work tommorrow
Old Oct 17, 2006 | 11:57 PM
AndyBlackFRST's Avatar
AndyBlackFRST
I've gor 3 of these,... took a while to setup too but worth the fun
Old Oct 18, 2006 | 04:47 PM
MB7201's Avatar
MB7201
Look in the manual, it should tell you the amount of turns out for each screw and return it to factory. If youve messed up the small screw the idle might be too low. Like said the low speed screw is evil try not to touch this
The easiest is idle screw to fix, does the engine keep going if you hold the throttle open a bit?
Old Oct 18, 2006 | 07:05 PM
wirralphil's Avatar
wirralphil
i touched the EVIL little screw an it's sorted now, set it up to 1mm open throttle and it was perfect,
found out it was the high speed fuel mix was over fuelling to much.
thanks for the help people
Old Oct 18, 2006 | 07:39 PM
Munch's Avatar
Munch
Mr. Sparkle!
glad its all sorted mate, took my savage x out today for a blast
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
FlashRS
Aug 30, 2015 08:07 PM
track.focus'd
Aug 12, 2015 05:53 PM
Zoggon
Aug 10, 2015 10:39 AM
