GEAR LEVER gaiter problem.....
simple question
how the fuck does a cosworth 4*4 gearlever knob come off ...ive pushed and pulled ...
turned clockwise & anti clockwise but to no avail
removed the top bit thought there might have been a grub screw underneath..
OH NO THERES NOT
want to fit a new gaiter but the hole is to small for it to fit over the gear knob
and as ive just paid £22 for it dont really want to have to cut the new one..to slide it over .....
HELP PLEASE ....
OH NO THERES NOT
HELP PLEASE ....
DK_SAFFY
the cable tie is not closed yet ...its the stitching at the top of the gaiter thats the problem...but 4/10 for the idea..
seems a pity to slice open a brand new one ..
might try the hard pull aproach ..knowing my luck the whole lever will come out in me hand
ELASTIC BAND
pull it harder, thats the right way & when you put the new cover on, make sure its inside out, upside down, so the cable tie goes on the inside, then pull it over itself
if you have twisted it then its fooked.
theres a D shaped plug inside the knob and you need to pull it off without twisting it.
as you have,it will be loose when pushed back on.
a new gear knob is about £15 from Fords.
btw, watch out you don't pull the full fitting off the stick.
your electric window switches are the wrong way round.
the twist and pull is what i have done, but it don't go back on as snugly as it was as said above i've prbably broekn something inside, a nice dab of silicon under there does the trick though.
where was the gaiter from and is it a straight swap?
Originally Posted by avid-fan
nightdavva cheers
if i carnt do.... it will take you upon that...
but really wanna get the vented splitter on her tomorrow...the morretes are on
next stop the spray shop...
carnt wait to see her when the spray jobs done...
Should look mint when the paint`s done...
James
the switches are the RIGHT WAY ROUND ...trust me ..
outside switches are for the front doors ..
your just looking at the picture wrong
i'm thinking you've previously thought the same though?
Originally Posted by dojj
remember that when you are fitting the new gaiter, put it on upside down over the top and secure the cable tie before folding it over
that way it won't show
Originally Posted by rstoughy
Deffo pulls off M8.
Open the sun roof and stand with a leg either side of the tunnel and get a straight pull up on it. That should do the trick
lol thats what the wife says too ...
its a c cup on top of the gear lever....on my car ..
ie the open space on the cup points forwards
so if it was twisted in a rant get off you bastard
it would be fooked ....
thanks all for your time and ideas
dojj fank you
dojj
tbh i was pondering before i put this thread up ...slight twist to the left and the right ...pulled it up a bit ... looked for grub screws
then looked for advice at local ford spares shop ....lol..hes known me since i was 12..
but the cunt still didnt know such a simple request ....
the real deal was one leg each side over the tunnel AND PULL LIKE FUCK ..
pf wins again ..
look in the photo thread room when shes out of the spray shop in about a weeks time ...
carnt wait
pf wins again ..
carnt wait
07-10-2015 12:56 PM
The Youth.
30-09-2015 09:59 PM
