How to bend some pipe?
Old 17-10-2006, 04:14 PM
CJBear
CJBear's Avatar
Default How to bend some pipe?
Got little problem me want to bend some pipes think is steel or ali anyway i stood on 1 end strained so hard nearly browned my boxers needless to say didnt budge an inch. What tools do i need to make my life easier bending some pipes without kinking it?
Old 17-10-2006, 04:21 PM
Turby2
Turby2's Avatar
Ideally you need a mandrel pipe bender which will bend the pipe without reducing the internal diameter. Very expensive though, so best off taking to someone who already has one.
Failing that a normal pipe bender but this will distort the tube as its bent eg powerflow or other custom exhaust place.
Old 17-10-2006, 04:42 PM
CJBear
CJBear's Avatar
So whats mandrel pipe bender?
Old 17-10-2006, 04:46 PM
scruffythefirst
scruffythefirst's Avatar
Pack it tightly with sand and get an acetaline torch and heat it up with one end clamped in a vice you should be able to bend it without distoriting. depends how thick it is though, you might have a problem if its a bit of scaffold tube.
Old 17-10-2006, 05:29 PM
foreigneRS
Testing the future
foreigneRS's Avatar
so you're an unsuccesful bender? hope you get some tips off more succesful ones
Old 18-10-2006, 02:24 AM
CJBear
CJBear's Avatar
how do you stop the sand from pouring out?
Old 18-10-2006, 02:34 AM
lil red scort
lil red scort's Avatar
i used to use a spring kit....heat.....and a vice. the spring goes inside and stops the pipe squashin then just pulls out. will need plenty of heat thow!
Old 18-10-2006, 05:54 AM
Jamz
Jamz's Avatar
Weld the ends up.
If you do try this use proper dried sand as normal sand contains moisture which when heated in a sealed tube will probably make it explode....
Old 18-10-2006, 08:37 AM
GARETH T
GARETH T's Avatar
this is the guy you need to chat too
Old 18-10-2006, 06:06 PM
CJBear
CJBear's Avatar
Only want too finish up the bathroom plumbing then finishings cannot afford paying for ready made bits then a plumber then a fitter me more broke than a pikey plan to make it look plush put it up for sale move somewhere cheaper like
Cosnada
07-01-2016 05:30 PM
07-10-2015 12:56 PM
stephenb4506
33
02-10-2015 06:25 PM
Fudgey
21
30-09-2015 06:19 PM
mpilk
27-09-2015 09:21 AM
Quick Reply: How to bend some pipe?
