Group B cars versus modern day WRC
#81
Proven Legendary Status
Why? Theres no limit to technology used (AFAIK) just the restrictor. So you can have a car that conforms to the rules, yet makes significantly more than 300BHP.
Ford, Subaru, Citroen, Mitsi etc all know this and Im 95% sure they all do they same.
#82
its not all about power tho, this yr f1 cars at some tracks were quicker than last years and there propa down on power!!!
i rekon over a stage then wrc would win
on the 1/4mile group b
carl
carl
#83
Rally nut
Originally Posted by Azrael
Originally Posted by TF Rallyesport
Originally Posted by 89XR2
Wrc tarmac spec cars are pretty much on slicks. They have only the slightest cuts in the tyres. And I would imagine the new tyres have advanced somewhat since the grpB days.
I heard a tyre expert say that modern top end "road" tyres have traction similar to 80's slicks. Full slicks have incredibly advanced since 80's. Looks how muchmore is dependend on tyre choice nowadays.
I still can't belive the 2.5sec for the Delta S4 even if I red it on lot of times.
#84
Originally Posted by Rich_w
Why had nobody mentioned that WRC cars aren't actually only 300-330 BHP. Thats just the gentlemans agreement between the manufacturers. Like 155mph limiters on BMW/Merc/Audi supersaloons not actually working until 170ish
Im led to beleive current WRC cars are all closer to 450-500
However, they DO have BIG torque numbers in the midrange
#87
Originally Posted by Bosch-Man
..Rich W you are led wrong then 500ft/lb torque YES!!
eg
Scooby
Ford
Anyway Phil, if were talking about wrong uns
#88
Most the points raised to have some bearing on the current WRC cars but major factors are tyre technology, damper technology, transmission and more to the point gearchange times/semi auto box - launch control, weight distribution, aerodynamics, materials used, the cars themselves as a package are easier to drive which combined with the fittest/best people driving them...you wont see Seb Loab smoking as well as being very committed he is extremely fit....I remember seeing Markko Alen eating fags in service....back in the Grp 'B' days rallys were won on longevity not just speed so you had more chance to catch up...not the case now...
All the wrc cars ive ever seen produce approx 310 bhp with approx 600lbs/ft of torque....as said above similar to the latest grp'n' subaru N12 car
#89
Maximum power of restricted car can be calculated from maximum airflow in the restrictor at speed of sound, as this is the limit. The only other oxygen comes form oxygen rich fuel but this is just couple percent of oxygen in fuel, Even if they make 350bhp it won't be much more. It can be seen in fast sections that they don't accelerate well. There is a vid of Panizzi in Pug 206 on Nuerburgring - on longest gearbox the car is pathetically slow, although it stil kills everything arround the corners.
I myself can belive in 2.5 0-100kph of WRC cars as I've seen it done on far less advanced road machine with only ~450bhp with much much worse torque curve etc.
#90
always remember poor old Ove. Toyota paid heavily for that infringement.
also seb was a top class gymnast as well. he is super fit.
and yes you are right about markku alen. serious man for the cigs!!
#95
With 1200Nm 2 their usual rpm around 3000 they would have much more maximum power then I would ever expect from a restricted car (can someone please calculate that? I'm far too sleepy at the moment). Not even rallycross engines with 45mm restrictors have so much.
EDIT: after little math: 1200Nm@3000 gives you 512bhp! 1200Nm@2500 rpm is still 427bhp. It's far too much. And they have maximum power a but higher then maximum torque so would have to have even more power. This sort of powersis impossible this low even in unrestricted 2 litre engine.
#96
Rally nut
Well it is what a guy from Bozian Team told me in Corsica this year, and we had a quite long talk about all and nothing and I don't think he told me crap (why should he ?).
I will try to contact a friend that works in F1/WRC world and I will ask him if he knows some things.
You know Azrael, nobody could really belive a 2L turbo engine could go over 800bhp few years ago, and I don't mean crappy engine, but relieable. All is possible, imho.
I will keep you informed.
#97
#98
#99
The F1 turbos were restricted in displacement only. Turbo inlet sizes and number of turbos were unrestricted. Nobody really knows exactly how much power those animals made....the Renault dyno went off the scale above about 1400 and they still had 1000 revs left on the tach.
A 32mm restrictor has enough airflow capacity to support just north of 300 hp at the high end of flow. HOWEVER, it supports quite a lot of torque well below the peak power level. This is one of the reasons that they run anti-lag on the cars. There are other reasons as well.
BTW, the 300hp (ballpark) figure is NOT a 'gentleman's agreement' it is a physical limitation based on CFM of airflow through the restrictor.
#100
#101
I"m aware of the difference. I checked the FIA site to find the technical regulations for the cars and was unable to find the restrictor sizes for each class.
I know Group N is 32 and Group A is 34, but I *thought* I remembered reading somewhere that the WRC cars (separate class from Group A) ran 32mm ones as well.
I've been wrong before......this may be another one of those times. Point being, there is still only enough air for just over 300hp in a 34 mm restrictor. I think that the math on the 32 comes up to like 270, but given advanced materials and electronics, I suspect that the factories can come up with 300 by tweaking the 'efficiency' end of the equation just a bit.
#102
32mm restrictor flows air at best maximum ~321hp
34mm restrictor ~363hp, remember these are figures for optimum wheather, humidity and shape of restrictor. Ford MS has reported focus wrc pulling 367bhp on dyno, maybe close to maxed out with a dyno miscalculation? I mean 1% calc.error will add/lose couple of bhp.
NO chance whatsoever wrc engine makes 1200nm not even 1000, 850nm has been reported by mitsubishi team(not works team) but i am sceptic to it.
WRC car beats GrpB anytime as long the road turns, the more, the more to wrc´s advantage.
Lots of silly rumours out there, realitycheck.
#103
#104
No ASAIK and mine certainly has a 34mm sat 50mm from the blades restrictor installed...
I'd have to see some serious evidence to believe those torque figures...the FIA dont create rules without some serious research...control fuel on world event is less enriched than the national fuel we use although the latest turbos have some massive boost pressure......
#105
In 1986 F1 engines used to run 5.4 bar boost Now that my friends is pretty mental!
In the later years the boost was limited to keep power figures in check
#107
GARETH Tback in 2002 a co-drive in WRC Focus costed something like a 1200 quid over here, so I bet in the left seat the price would be absurd :-(
#110
Originally Posted by capri-rs
"To give you an idea of the kind of performance GroupB cars were capable of I'll mention that in the 1986 season Henri Toivonen made two laps around the Estoril circuit, during a stage of the Portuguese rally, the fastest of which, in 1 minute and 18,1 seconds, would have qualified him in the sixth position of the F1 Grand Prix that same season. Ayrton Senna had the Pole Position in the 1986 Portuguese Grand Prix in 1 minute and 16,7 seconds...Toivonen was using the Lancia Delta S4 and was accompanied by his usual co-driver Sergio Cresto. Keep in mind however that current GroupA and WRC cars are even faster, overall, than GroupB cars used to be. This is mainly due to technology advances in tire formulations and suspension technology leading to GroupA cars being faster around corners but losing on straights as compared to GroupB cars"
cut out from this page http://www.rallycars.com/Cars/Cars_Background2.html
#111
havent got a clue.just found that info on the site i linked to.
ohhh just found this on wikipedia
"After the deaths of Senna and Roland Ratzenberger in Imola in 1994, the Estoril track was changed, with a new chicane built in place of the tank curve, as a security measure. Estoril was then considered an unsafe and outdated track, and the last Portuguese Grand Prix was in Estoril on 22 September 1996"
1.18,1 seems a bit optimistic considering the fastest lap in the F1 race that year was 1.20,9 (nigel mansell) but what do i know
track.focus'd
12-08-2015 05:53 PM
Versus_Creations
24
05-08-2015 09:32 PM
