CAN YOU TURBO GENUISES HELP ME WITH A TURBO LEAK.
hi guys this the second time i have taken my turbo off my fiesta rs turbo.
please have a read at the bottom of page 2 on the update on 13/10.
rob
http://www.fiestaturbo.com/forums/fi...0-vt138345-35/
rob
Former Sponsor
Hi matey
first off, id be on the blower to TT if they rebuilt it...
Also, the print out you mentioned, NOT ONE turbo ive had balanced has come with a printout.
Possibly TT were giving people printouts, but got fed up of all the phone calls from people asking what it meant...
Anyways, it is hard to tell from the pic what it will be for 100%
I take it theres a gasket on oil feed pipe.
If TT are no help, i can strip and have a good old look if you want.
Edit....just looked more closely at the pic, on photoshop and it looks as though the core isnt sitting in the exhaust housing flush. Try really tightening the bolts.
Also, IMO, those tags are fooking useless, and should be half circle ones.
Carl
click the top link for info
Carl
Originally Posted by Carlsworth
Hi matey
Carl
Carl
i may just try my old turbo unit back on as i believe i may of had a blocked oil return which was causing tiny amounts of blue smoke.i picked this turbo up for £30 with warranty left + see it running on the guys car before i took it.
as in printout i got last time a yellow slip stating what it had been through, spun up tp 100000 rpm etc.
if you took it apart, can you balance it back?
standard practice matey
any of you guys help me out to try and solve this before i take the turbo back off?
i've got this problem on my car. its a fiesta turbo engine but i've got a t3 fitted. oil seems to be leaking out of the compressor housing.
is the actual problem here the oil return fitment at the block getting blocked? if so whats the best way to sort it without tapping into the sump etc.
cheers chris
cheers chris
Former Sponsor
Originally Posted by paceo
ian howell has suggested the valve guides and breathers that is a possible cause.
got the same fucking problem with a customers car at the mo,....
suggested breather etc,...
he says they good....
so now ive had to strip the turbo under warranty, to have a look,....
fooking nobend, theres fuck all wrong with the turbo....
carl
carl
what car was it off mate?
JK12
33
26-04-2021 12:09 PM
