Fuel Cells / tanks
Morning, just wondering what everyones opinion is of boot mounted fuel cells/ fuel tanks such as the pro alloy ones here http://www.proalloy.co.uk/cgi-bin/si...79&id=proalloy in terms of safety and weight distribution?
Originally Posted by Pennywise
Originally Posted by jbrayley
in terms of safety and weight distribution? ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
Jeebus
Safety, I guess it is better if mounted behind a firewall.
Weight distribution wise, well I guess putting 60litres of fuel plus a tank (total about the same as a passenger?) behind the rear axle and quite high up at boot floor level is never going to be great, but with a RWD/4x4 car you are limited for space any lower! I am sure improvements could be made if you could get it between the axles and down to the main footwell level.
Morning, just wondering what everyones opinion is of boot mounted fuel cells/ fuel tanks such as the pro alloy ones here http://www.proalloy.co.uk/cgi-bin/si...79&id=proalloy in terms of safety and weight distribution? ![Big Grin](https://passionford.com/forum/images/smilies/icon_mrgreen.gif)
safety wise it has to be better than a standerd tank under the boot floor
When mounted between the rear strut tops you could take imact from all angles & it would be extremely unlikely to split.
As far a weight distribution could it be better than directly over the rear axle ??
ProAlloy`s welding quality is second to none IMO.
Has impressed & prompted comment from people in the motor trade i have shown the car to
Phil has a valid point , however, with RWD cars a certain amount of weight over the rear wheels can be a positive advantage , stops the wheels spinning and even heats up the rear tyres a bit quicker . The current BTCC cars have their tanks located behind the drivers seats for instance as theyre FWD so more weight required forward .
for safety this is probably a bit better , youre less likely to get T boned than rear ended and a fuel cell at the back of the car may be slightly more exposed .
![](https://img.photobucket.com/albums/0703/TonyRyan/int.jpg)
![](https://img.photobucket.com/albums/0703/TonyRyan/tankbig1e-1.jpg)
2 x different locations in the same car , just as an example
Thanks guys, just wanted to make sure im doign the right thing ![Top](https://passionford.com/forum/images/smilies/smile011.gif)
