Rev counter on a mk6 ford escort
i've looked for months for a guide on this, but gotten nowhere
My car is a escort CL 1998 R plate.
And it came with the destruction derby car picture on the dash instead of a rev counter.
i fitted a set of RS2000/GTI White dials to it everything works speedo ect
but the rev counter doesnt
i've heard some stories it needs wireing up, Or its not plugged in properly
can someone get me a guide on this.
Very much apreshiated
Gary
Gary
Fucking superstar........
Originally Posted by 1stEscort
Rab
Yes 1.6 zetec
i cannot find it anywhere
and luke89 said its got an internal one or something
Yes 1.6 zetec
Sure it's not lurking in there behind the fan motor?
There will be a connection on the engine loom to main car loom multiplug that will have a feed for the rev counter on it
Yours has internal EDIS, so no module in the engine bay, like mk3 fiestas and mk5 escorts have! Internal means in the ecu, so give up searching now
To be honest, it should have worked straight away. Even 1.3 & 1.4 engined escort mk6s can get a working rev counter by swapping some standard clocks.
Double / triple check your installation first. Those multiplugs on the back are a bit of a coont.
I swapped my one a while ago and luckily had the wire already there
Just found the thread I started and it would probably be better than that other link, as yours should have the same clock set as my one did. Its got more specific info on what to wire up
http://www.ford-force.com/forums/ind...topic=5352&hl=
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
before i start messing then, i might buy a second set of clocks, cause my rev counter may be fooked
ekjim
17-08-2015 08:57 PM
cozzy jeff
14-08-2015 05:46 PM
