Windscreen fitting info req.
Old Sep 27, 2006 | 06:53 PM
cosworthbs's Avatar
cosworthbs
Default Windscreen fitting info req.
Does anyone on here know anything about fitting a windscreen. As i want to fit one into an escort.What i want to know is do you have to fit the rubber moulding to the windscreen before the windscreen is fitted to the car or after cheers.
Old Sep 27, 2006 | 06:55 PM
Physio's Avatar
Physio
Fit it onto the widscreen before fitting the widscreen
Old Sep 27, 2006 | 07:12 PM
Alvyn's Avatar
Alvyn
the above depends on what year the car is
Old Sep 27, 2006 | 07:40 PM
Thrush's Avatar
Thrush
Irritating c........
As said, depends what particular Escort, but all need the "rubber" fitting to the screen before being laid into the vehicle.
Mk1 + 2 Escorts are what we call "Etch-in" screens : The rubber trim is left on the vehicle, with only a rubber strip removed from it. THe screen is then fitted to the car, lipping the rubber trim around it. Then the rubber strip is re-fitted to the rubber trim, and it's width is what tretches the rubber trim tight to hold the screen in place.
The mk3 and mk4 Escorts are what we cann "string-in" screens. The techincal name is "indirect-glazing". This means that the screen is held in place using the rubber trim. You remove the rubber time from the vehicle, fit it around the windscreen and then, using a length of thick string (hence the name) or thin rope, you "string it" back into the vechicle.
The mk5 onwards Escorts are bonded screens and are called "direct glazed" screens. This means that an adhesive bond line is applied to the aperture of the car (or screen) before being laid into the car, and it s the bond that keeps the windscreen in. These screens require the rubber trim (a "goalpost trim" that only goes across the top and down the sides of the screen) be fitted to the glass first, then the adhesive bond is applied to the cars aperture (or to the screen directly) then the screen and trim are laid in as one. The scuttle panel is then fitted last, covering the bottom of the screen.
Old Sep 28, 2006 | 08:14 PM
cosworthbs's Avatar
cosworthbs
great thanks the mk v sceen is the one i want to fit. Thanks all
neil18
Mar 14, 2016 01:08 PM
borboyous
Aug 22, 2015 11:17 AM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Aug 9, 2015 07:03 PM
jay030787
Aug 5, 2015 09:28 PM
