Plate diff or Quaife ATB
what are your opinions and why when running a high powered FWD car? please bear in mind that the car will mostly be used on the road but will also be tracked and as many 1/4mile/top speed runs as i can...so call it about 80% of its life will be around town and 20% will be racing
there will be a high/low boost function to help traction
is the plate diff really that hard to use for everyday use? or are the advantages of having the plate diff outweigh its hard to turn characteristics?
i like the car to be fast and quick through the corners so the steering does need to have good feel to it around a track or when fast road driving
thanx for any input
bassboy
thanx for any input
bassboy
hi mate
plated front diff is ok proving that you have it set at 60/70 ft lbs (progressive) and ask the person that is building it tell them that you want it set up for road use and shout road use because most of them don't understand the meaning what road use is ok gripper man
and they will set it up a with different plates and different ramp angles
the idea of having it set progressive is that when your cornering the one wheel will spin faster than the other without the plates grinding against each other
don't have it full on unless your doing straight line stuff or on the lose
cheers marco
cheers marco
I was told that an ATB is perfect for fast road use, only disadvantage being if one wheel lifts, you loose all drive to the wheels. I have an ATB in my RS 2000 and it outstanding. Bearing in mind i drive our crappy country roads hard, i've never had a problem with loosing drive to the wheels due to lifting off the ground. But then as Marco says you can set a plate diff up to suit your type of driving.
cheers for the comments so far....
the thing is the power will be around the 400hp mark if not more...hence me asking about the plate diff...is it was less, i would go for the ATB no problem....
Marco...kiddah bhaji?....if the diff is set how you described, how much of a difference would that make over the ATB?
chip...howcome you prefer the ATB?
bassboy
bassboy
A plate diff can be far more harsh than an ATB as its a competition item, it'll pull your arms out of their sockets lol
The ATB would be more sociable to live with day to day, but compared to a standard RS LSD it has far more of a 'bite' to it.
bassboy
I've no idea what its rated to. On my car (150bhp) its outstanding, makes such a difference to both cornering and straight line traction. The car won't really loose grip in the dry. In wet/greasy conditions, while it will start to spin up round corners, its still holds the line you want, it doesn't understeer as it used to. I'm not sure how well it would workin on you car though as you'll have WAY more power/torque to put down than me!
see thats the thing...not many people have tried and tested at that sort of power....
im just wondering what it would be like having a plate diff set up how marco has described compared to a Quaife ATB diff...
how are the Plate diffs for cornering? or is that a stupid question
bassboy
bassboy
bassboy
bassboy
but saying that the ATB isn't 2wd all the time the ATB sends power to each wheel rapidly and if you get one wheel airborne it will then send all the drive to the wheel that is in the air not to the one that is on the ground but still is a very good diff
a plated diff is 100% 2wd all the time even if a wheel is in the air you still have got traction from the other one that is on the ground
but like i said you have to have it set for road use (not too much pressure on the plates)
one wheel would need to spin quicker than the other when cornering
both diffs are as good as each other with the plated diff at some point you will need to change the plates as they do wear out but that takes ages
with an ATB is normaly hastle free put it in and forget about
i still rate the plated diff over the ATB for compertion use( racing) mainly because it 100% 2wd all the time
Marco
I prefer the ATB on a road car just because you literally cant tell its fitted, it still parks without any hassle etc, no issues with working against it at low speeds.
They also work very well on track IME, the diff attempts to apportion torque in the correct ratio to maintain traction on both wheels as far as possible rather than allowing one to slip slightly before it acts.
In theory with one wheel off the ground, it should still work, but i havent tested that, so if marco says otherwise then fair enough, but the way the diff is designed is meant to allow for that as its only supposed to supply torque when there is resistance to apply it too
I know plate diffs are a bit mad - especially when they are cold, they pull all over the road and stuff.
Hi Chip
yes it's an Anti torque bias diff and it doesn't work when a wheel is air borne it sends the power to the one in the air and you have no drive untill the wheel is back down on the ground
marco
marco
so in theory, with both of them...if i get wheel spin, im just gonna spin BOTH wheels at the same rate? however, with the ATB, it allows both wheels to turn in the same direction but allows a slight bit of slip so the cornering is more plesent and wont try to pull the wheels back to the straight position?
with the plate diff...as the wheels are both turning at the same rate...when cornering, it will try to pull the wheels to a certain direction (im sure when turning, one of the wheels spin at a different rate to the other?)...however, setup how Marco has described...will allow a slight variation? but will still try to pull the wheels straight if you give it too much LOL
am i right in thinking the above or have i missed something?
bassboy
bassboy
thats a misconception about plated diffs are only mad when you have had it set with too much pressure on the plates you seem to forget that the plated diff is fully adjustable in everyway and 100% 2wd all the time
not noisey when they are set for road use
bassboy
ahhh yes...anyone know what the BIG power Focus RS use? if its plate or ATB still?
MARCO wake up!! lol whats a plate diff like which has been setup as u described?
bassboy
bassboy
Originally Posted by TF Rallyesport
thats a picture of an engine,not a car.
if you have 400bhp the gearbox and driveshafts will be a bigger concern.
bassboy
bassboy
bassboy
bassboy
bassboy
bassboy
bassboy
jup car and piss off
DavidK
27-09-2015 02:55 PM
