HCS Fuel mixture - easy enough for a garage to set?
Redumbdancy
Pretty sure i knocked and altered my fuel reg the other day when i was re-fitting my air filter - is this an easy job for a garage to set properly?
how did you knock it though? it should have a tamperproof cover over the adjusting screw? and then you would have only knocked it's setting about if you had a screwdriver in your hand and were adjusting it?
a garage with a gas analyser should be able to get it back to something like it though.
Stu @ M Developments
41
21-08-2015 06:47 AM
