Transit experts..please help!
as doo says. pop into ford with your reg and it will tell us on etis,ecat, microcat
or if we actually feel like doing work its on the inside of the chassis cab
but etis tells you everything apart from the name of the birds you done up the arse in the back,,,,,, ever since i got caught out with a fucking ranger i have that saved on my pc at work
pm me and i can check too,,,,, but unlike tony i can get net access at work as im "special"
they don´t all say it on the door.if it is a rear wheel drive medium or long wheel base it will be either a 90,100 or 125ps. if it is a front wheel drive(short wheelbase only)it will be a 75,85,100 or 125ps. as said above,if you pm doo he should be able to tell you,or ring your local ford dealer and they might do it. i could do it but am not back at work till next thursday.
bryan
bryan
i can do it tommorow
ill be at work at 730ish as i fucking love my job,,,,,,,, well the fucking driver that picks me up loves his job otherwise i leave 20 mins later to get a train into work that allows me to arrive at work at 830
fucking transport system
1st to 200 without NOS
Originally Posted by DOO
I can do it now ! just need the reg
post up or PM the vin or reg and i tell you
WFOVXXBDFB4R47540
DIAMOND WHITE
MODEL = 300S
DURATORQ DI (100PS)
FWD
BUILD DATE 25/02/2004
WFOVXXBDFB4R47540
DIAMOND WHITE
MODEL = 300S
DURATORQ DI (100PS)
FWD
Doo... I thank you
we got new new shap 110hp ones at work,,,,,,, they still are underpowered tbh
martin remember that the injectors, pump ect all are coded to the one ecu
its not like on a normal car you can just do a swop, all the new fords have bundles of ecu's that all talk to each other
I'm sure Martin is probably aware of these issues with todays climate in the motor trade Ginge.
just incase, you would be suprised the amount of TRADE people who get secondhand engines and then call us up when they cant get the cars to start
its happens ALOTMORE than you think
and its a pain in the arse at times too, volvo are worse though, everthing in there car is a fucking module, you cant even change the rear veiw mirror in some models without a software upgrade , just cause they fit a sensor for the alarm in the mirror
also electric window switches too are also modules
was trying to be helpful, im sure some people never new that
Ok, now I know it's a 100ps am now wondering what difference there is between that and my current 75ps engine? Are they the same basic unit with different turbo and or injection system? My van is a 260 and the donor is a 300 any differences in suspension other than uprated springs?
Ok, now I know it's a 100ps am now wondering what difference there is between that and my current 75ps engine? ?
Thick spanner monkey
Don'y Yb's fit in transits???
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
