Engine rotation direction?
Old Sep 19, 2006 | 11:18 AM
Andreas's Avatar
Andreas
Default Engine rotation direction?
About to get the top off and have drained all fluids and removed most hoses and connectors and noticed the workshop manual says "note rotating direction of cambelt"
So in what direction does the cams rotate?
Standing in front of the car looking at the engine...
O-O <----cam pulleys
Do they rotate clockwise or anti-clockwise?
Perhaps even easier to answer, what direction should the crank pulley bolt be turned to turn engine forward?
Old Sep 19, 2006 | 11:19 AM
if you mean a YB
The top of the belt moves to the right as you look at it from the front (ie clockwise)
you can tell this as its always the opposite side to the tensioners.
Old Sep 19, 2006 | 11:20 AM
GARETH T's Avatar
GARETH T
clickwise
they say not the direction of the belt so you put it back on the same way if you are re-using it
Old Sep 19, 2006 | 11:22 AM
Andreas's Avatar
Andreas
Chip, cheers.
So I guess I should turn the crank shaft pulley clockwise to turn it into TDC position?
/Andreas, about to loose my engine work virginity.
Old Sep 19, 2006 | 11:23 AM
Originally Posted by Andreas
Chip, cheers.
Yes mate thats correct, keeping the tension on the distributor side of the belt.
Andreas's Avatar
Andreas
Thanks Gareth, wont re-use it as its more soaked up with oil than one of Rainbums dildos.
Mark Mawson
Aug 31, 2015 07:09 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 07:06 AM
