one 4 the tuners.....
saff is working!!!...atm
whats the differance setting cossies up with differant actuators....-31....-34, ive got a ut t38 and ive got a -34 (light blues,around 400bhp),but ive been told that he'll set the car up with a -31,the -34 is nearly new,so can u tell me the change
-31 base lift off pressure is 8psi, -34 is about 14psi (i.e. minimum boost before opening wastegate)
-31 is more progressive than the -34, which is 'snappier'.
wanted a bit background on it first, but anyway phoned him up and he sorted it out (i have the knowledge).........nice 2 c that if it hasn't been wrote on here somewhere...the no it all's havn't got a clue
Caraholic
Pete,
I would personally run a -31, as the boost curve is more progressive, which with a 2wd is nicer to drive. The reason why most fit a -34 is that they don't have the Amal valve connected, so need the stronger spring to maintain the boost or want to stop the wastegate from lifting at high rpm.
ello mike....its sorted now,spoke 2 grove 2day,amal valve was conected b4,but thats in the past....-31 is the future....p.s enjoy the free laps fella.....hope the card works
