Tube chassis MK4 escort F.A.O Radders
Well guys and girls, I keep getting asked for a preview on radders/pennywise escort cosworth conversion and he's asked if I have pics to post so thought its about time I did
these pics are the the start and main structure of the tube chassis,
next is position the rear coil overs and fabricate the mounts so that the reat of the rear cage can be added, Then on to the front end for front strut mounts and the engine.
Originally Posted by GARETH T
what pipe bender you use danny?
Looks good.
Is that a BMW rear beam see in there?
Will you have any probs welding the two steel tubes onto the cast iron diff cover?
Is there going to be some more triangulation in there as the space frame develops?
Yes there will be alot more tube work, as I wrote at the top this is the start of the main chassis, theres no welding onto cast iron?? the diff bolts up into position, those tubes are welded to steel diff mount brackets.
see you friday radders! shame you cant see the pics
Originally Posted by lloyd
that is a great project. .will it pass a mot test with a tube chassis?.or is it track use only?
how long till its done? cant wait to run this against my escos.
Your going over 400bhp arnt you? Cant you turn the boost down just for that day
Im only going 803's and T34.48 (for now)
Not sure on completion date either...
