UNDERDRIVE CRANK PULLEYS
Hi fokes
got a lightened underdrive crank pulley, and i must say im impressed with the effects
any bad points about them ?? its lost 2.6lbs on the drive by doing this swap, so a sizable gain of about 6bhp not bad for 40 quid
well apparantly every 1lb you lose in wieght you gain an everage of 2.7bhp on the wheels, because there is less weight to have to rotate
sort of like running 19's then going back to 15's if you get me? well thats what i was told
which is just like 15s and 19s
Resident Wrestling Legend
i have never understood how making smaller pullys made you more power
if you've got s amleer pulley then, by default, the other stuff it's turning doens't work as effectivly, and so, by defualt, has to work harder, making any gains provided by the pulley made smaller innefective at best, and, at worst, damaging to the rest of your car
if you want to make things do less work you make the pulleys bigger on the items you want turning, redusing the amount of effort that is needed to rotate those anciarlies
if you half the rotational speed of your alternator will it still produce the same amount of charge?
what about the power steering pump?
will it affect the water pump flow also?
make it bling by all means to make the riciprocating mass lighter to give you less power losses, but also be aware that certain engines will incorporate a harmocin balancer in the cranck pulley and you may get vibratiosn in the eingine by removing the one fitted
smaller pulleys are about allowing you to rev the engine higher without overspeeding the water pump or alternator, on a normal rpm road car they are of no use.
weight saved off the engine roughly translates to a multiple of that weight saved off the car.
So losing 2 pounds off the pulley might equal losing 20kg off the car in first gear in terms of acceleration (and then less in subsequent gears of course)
I personally wouldnt be able to notice it, but if you can then maybe your arse dyno is more accurately calibrated than mine, or maybe you are imaganing it.
DixieTheKid
11
06-06-2020 11:20 AM
jonfoc
16
11-09-2018 05:35 PM
timsrs
22
24-09-2015 08:14 PM
