QUICK...........saff 4x4 offset
Old Sep 14, 2006 | 05:30 PM
gingeRS's Avatar
gingeRS
Default QUICK...........saff 4x4 offset
what is it.....please
asap
thanx
Old Sep 14, 2006 | 05:31 PM
charlie luciano's Avatar
charlie luciano
Default OFFSET
et 35
C L
Old Sep 14, 2006 | 05:36 PM
gingeRS's Avatar
gingeRS
cheers
will 18's with a 45 offset fit?
with coilovers
Old Sep 14, 2006 | 05:40 PM
charlie luciano
Default OFFSET
Sorry can't help withthe last question, personelly i have been advised not to fit 18's to a saff apparently it makes the ride shat
C L
Old Sep 14, 2006 | 07:16 PM
Mr 19"'s Avatar
Mr 19"
Standard offset is 40mm.
Old Sep 14, 2006 | 07:21 PM
Mr 19"'s Avatar
Mr 19"
If you want to those wheels, it depends on rim width and tyre width. I would use a spacer of 5mm to get the standard offset and to clear the spring platform if you don,t use coilovers. You should use 215/35 tyres to get good clearance, and you will probably have to roll out your wheelarches too and cut away the upper mounting point for the inner plastic wheelarch.
Old Sep 15, 2006 | 12:20 PM
AGAR-COSWORTH's Avatar
AGAR-COSWORTH
Redumbdancy
Yep ET40 for definate - its stamped on my 4x4 saff rims.
Old Sep 15, 2006 | 01:21 PM
Cawood's Avatar
Cawood
doesn't the offset depend on what width alloys you choose?
Old Sep 15, 2006 | 01:22 PM
Rab's Avatar
Rab
Fucking superstar........
Yes.
Old Sep 15, 2006 | 01:26 PM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
The standard rims are 7", so as has been said, it depends on the rim width. I would suspect they are 7½ by the offset, so offer them up to see if they clear. I think they will look to inset and 5-10mm spacers would be required to look good.
Old Sep 15, 2006 | 08:55 PM
AGAR-COSWORTH
Redumbdancy
When refereing to "they are 7.5 inch by offset" what alloys are we refering to here, as the sentence before you confirmed that the saph 4x4 rims are 7" wide - are you saying there were two widths of saph 4x4 rims avialable from ford?
Old Sep 15, 2006 | 09:07 PM
Mike Rainbird
Caraholic
No, I'm saying the 18" wheels that he likes in ET45 are likely to be 7.5" .
Old Sep 15, 2006 | 09:25 PM
AGAR-COSWORTH
Redumbdancy
Ahh all makes sense now
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
cossie330
Sep 27, 2015 04:13 PM
