European Ford Event - Netherlands 10/09/06 (56k wanring!)
#42
ok...so again 3dr ?
but so you can be sure that every work is done to your thinking.
and if later something goes wrong, normaly you know quickly what´s going on.
in germany we say: "if you want something be done right, you have to do it by yourself !"
#43
with only 2wd i hope to get nearly same performance than before with 4wd. caused of less weight (-70kg) and less power-lost by the drivetrain (only-45HP,not 90HP).
also i can use the standard pace dry-sump kit. this i think is necessary if i want to drive at the HHR and the Nordschleife with nearlly always full throttle for more than only a few minutes.
and i want to be sure nothing will brake. so only than it would be real fun..
#45
This year the show won't be at the regular place in Landgraaf. Check the site: http://www.europeanfordevent.nl for the new location
borboyous
22-08-2015 11:17 AM
