Boot Problem
Old Aug 22, 2004 | 04:57 PM
Lee_Rs's Avatar
Lee_Rs
Default Boot Problem
When I lock the car up on my ERst it locks both doors up but not the boot. I can hear the central locking for the doors and the locking for the boot yet when the car is locked if you just push the boot lock in, it opens up the boot yet the doors are still locked.
How can I fix this??
Old Aug 22, 2004 | 05:21 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
I had this on my escort. Its the actual mechanism sticking. I could lube it up and it would be fine for a while, but then would go back to this problem. Try a scrappy(or you could buy a new set from Ford) or just delock the lot and fit the extra solenoid motor and switch.
Old Aug 22, 2004 | 05:22 PM
Ryan's Avatar
Ryan
sounds like the solenoid has packed up or if not that then the lock is stiff or jammed
Old Aug 22, 2004 | 05:39 PM
Lee_Rs's Avatar
Lee_Rs
Where do I spray the lube Lads?
Old Aug 22, 2004 | 05:40 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
on the crack, so jus as u slip it in, it runs down to the right bit in time i'll get my coat.........
Old Aug 22, 2004 | 05:42 PM
Lee_Rs's Avatar
Lee_Rs
LMFAO! just int he keyhole or what?
Old Aug 22, 2004 | 05:44 PM
Rich_w's Avatar
Rich_w
Everything. Inside the lock on the tumblers (so you know its properly unlocked) and on the linkage inside the lid itself.
(Take the 6 or so plastic 90 degree screws out and drop the middle plastic trim down.)
mk1turboestate
Dec 2, 2015 08:31 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
Iain Mac
Sep 13, 2015 09:16 PM
The Enigma
Sep 12, 2015 10:12 PM
chris m1
Sep 7, 2015 08:02 PM
