S2 breather problem
Old Sep 10, 2006 | 12:34 PM
Hrsturbo's Avatar
Hrsturbo
Default S2 breather problem
my car has been cutting out when its been left to idle and I've been trying to find out what's wrong then today I accidently left off the black box breather thing next to the cam belt coming from the rocker cover and now it idles perfectly!!
it used to cut out when I pulled off the oil filler cap but now as engine will only idle when the breather box thing is removed I can remove the cap and its fine! what does this mean??
is my engine blowing up or is something blocked??
any help appreciated, thanks
Old Sep 10, 2006 | 12:38 PM
Paddy's Avatar
Paddy
Legend
Sounds like the breathers blocked [unless you've taken it off an put it the wrong way round, think they work on a valve?]
Ford still do them and they cost fuk all or upgrade to a baileys unit
Old Sep 10, 2006 | 12:43 PM
Hrsturbo's Avatar
Hrsturbo
well that's a relief! thought it was leading to something expensive! what kind of breather do I need? I take it I need something a bit different to the little K&N type one which bolts to rocker cover which you see in every motor spares shop??
Old Sep 10, 2006 | 12:51 PM
Paddy's Avatar
Paddy
Legend
Make sure that when the breathers off there's not plumes of smoke coming out? Could be an indication of bottom end problems...
If I remember correctly, that breathes back to the crank?
A Baileys [or whoever else, GRS make one I think] system replaces the whole breather system and is far better than the plastic valve thing.
But having said that, the direct replacement costs fuck all from Ford
In fact I had a spankers one I left as a spare my old RS that someone off here bought, they may still have it as a baileys unit was fitted... can't remember his username but Guzzler will know
Old Sep 10, 2006 | 01:15 PM
Hrsturbo's Avatar
Hrsturbo
is this what i need??
http://cgi.ebay.co.uk/BAILEY-OIL-BRE...QQcmdZViewItem
Old Sep 10, 2006 | 01:18 PM
Paddy's Avatar
Paddy
Legend
I wouldn't say you NEED it!
But if you were going to upgrade from the standard item, then that's the one to get and you could probably get a better deal buying that directly from Dan@rapidford via here
Old Sep 10, 2006 | 01:24 PM
Hrsturbo's Avatar
Hrsturbo
ok thanks I think I will get the standard one till I can afford to splash out again as they only few quid!
cheers for help
Old Sep 10, 2006 | 04:50 PM
Hrsturbo's Avatar
Hrsturbo
Back again, just a thought, if I was to vent the rocker cover to the atmosphere, what pipes do I need to block off?
I take it the one which goes to the inlet manifold needs to be blocked or the car will stall. What about the big black plastic pipe? what do I do with that??
thanks
Old Sep 10, 2006 | 06:45 PM
Hrsturbo's Avatar
Hrsturbo
any one??
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
