Programing the door locks on a ST200
How do you program the door locks so that when you press the open button on the remote once, just the drivers door opens? Also if you you press the open button twice within 3 seconds and all the doors open.
Mine seems to have lost it's program on the front passenger door only, the rears still stay locked.
erm if you mean when you turn the key manually you got a issue
if you mean the remote no longer works then you buy a new batt, turn the key in the lock to open and close the door a few times till the red light on the dash comes on then press the remote open button
hey presto its programed,,,, we charge 1 hours labour for that at work too
The remote still works fine, its just that when you press the open button on the remote once, just the drivers door should open unless you press the open button twice within 3 secounds then all the doors should open.
My front passenger door now has a mind of its own. Sometimes it stays locked, sometimes it opens. I know you can program the locks so that they work as above or they all open together on one press on the open button on the remote. Question is how do you do it? In the owners manual it states refer to dealer to have it programmed. I believe its done by pressing a combination of the remote buttons but I'm not sure.
Here you go mate
1. Unlock the car and then hold down the lock and unlock buttons on the remote for 4 seconds. The indicators should flash and single door unlock facility is enabled (i.e. just the drivers door opens).
2. To unlock all doors just press the open button twice.
There are a few more aswell---Here you go
Auto Lock---
1. Turn on the ignition but don't start the engine
2. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
3. Turn off the ignition
4. Lock the door by pushing in the button below the handle, and then pull the handle slightly to reopen it (Repeat this operation three times)
5. Turn on the ignition but don't start the engine
A beep should be heard
6. Lock the door by pushing in the button below the handle and then pull the handle slightly to reopen again
A final beep should be heard
Global Open and closure--
If you unlock the car with the remote, but keep the button pressed....It will fully open all windows..
Keep your finger on LOCK and it will fully close all windows
Auto Lock---
chowfornow
14
Jan 5, 2019 09:01 PM
Vacuman
Sep 22, 2015 12:09 PM
