3 BAR MAP SENSOR QUESTION
Old Sep 8, 2006 | 09:20 PM
STUCOS's Avatar
STUCOS
Default 3 BAR MAP SENSOR QUESTION
Ok folks have 2 map sensors in my garage one is a 3bar,what is the number stamped on it ?also does it have to be mounted horizontal ,and up side down or can i mount it any way
cheeRS stu
Old Sep 8, 2006 | 09:31 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Needs to be mounted upside down
Old Sep 9, 2006 | 04:58 PM
Stu @ M Developments's Avatar
PassionFords Creator
APS or SPA 05 is a 3bar.
Old Sep 10, 2006 | 08:39 AM
Eagle's Avatar
Eagle
Super Moderator
why ????
Old Sep 10, 2006 | 08:55 AM
cossie604's Avatar
cossie604
mounted up side down to try and stop moisture being a problem internaly??
Old Sep 10, 2006 | 08:56 AM
Eagle's Avatar
Eagle
Super Moderator
so they put it under the header tank ...
i have no idea as to why
Old Sep 10, 2006 | 09:08 AM
cossie604's Avatar
cossie604
Moisture drawn in from the inlet plenum on cold start ups.....most map sensors..in fact every map sensor i can think of off the top of my head is mounted upside down....fords/vauxhalls/renaults....
Old Sep 10, 2006 | 09:13 AM
Richie.'s Avatar
Richie.
aka Turbosailorboy
why ????
Something to do with the ceramic diaphram inside Alters the base signal by about 0.2 bar iirc. When MSD mapped mine Stu told me mine was the wrong way up and made a little bracket to mount it upside down
Old Sep 10, 2006 | 09:22 AM
Eagle's Avatar
Eagle
Super Moderator
cool .. always wondered that
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Kam B
Sep 24, 2015 10:40 AM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
