koni adjustables settings
I can only talk for myself, and medium is fine. My car is only used on the road though. I'm sure i'd adjust them to hard if the car ever went on track.
i dont think there is a reason to have em on hard all the time, my old cossie was set to medium and was fine, i set my new cossie to hard and am just to lazy to change it
at the moment I have standard shocks and lowered springs 25mm, would you think that having my konis set to medium I would notice the firmness.
Getting my konis fitted next week!
To quote from the other post: -
Backs can't be adjusted quite as easily (you have to remove lower mounting from car and then push up and turn to the setting which then clicks into place - from memory), and have either 3 (soft, medium, hard) or just the two (soft / hard) settings.
If your not sure, ask whoever is fitting them to set it up for you on sayt medium, go for a good drive, come back then get them to set it up hard, then take it round the same route.
I'm sure you'll then know what's right for you.
truffleshuffle
10-09-2015 09:35 PM
