Widening front track on a cosworth- Reyland has...
...already attempted it an I believe the job is finished, I am widening the track on my sapphire cossie but to inprove the lock.
I have a wider steering rack with longer arms, it gives about 1.5" per side extra width, I move the TCAs out an inch and a half and will fit the compression struts so the front ARB isnt a problem I think there is enough adjustment in them for that amount. All I need then is top mounts sorting, I have solid top mounts for the o/e strut position but will need the tops pulling out around 1.5" to compensate the extra width, will these on the right get the adjustment that I need:
I have found these in the USA, look like a proper piece on kit, drags the Sierra into the 21st century... just
Will these do it or is it left to a Reyland style job of cutting the strut tops off and welding new wider top mounts on??
You arent going to be able to move it 1.5" on those eccentric mounts as they dont move that far, and on the yank type ones i doubt you can either as the spring would end up rubbing in use i should think.
you need what the jap boys use on alot of the Apexi and tein stuff.
there top mount are superb.
Have both massive amount camber and caster adjustment aswell.
Something similar to this:
Obivously these ones are purely for camber.
Ryan, still limited by the amount of clearance the spring on the shock has from the bodywork though of course.
Mr C, have you actually looked up from underneath to see if moving it 1.5" is an option in the first place without rubbing on whatever shocks/springs you have?
all you need to do is make an extended/higher wider turret top on the car to accomodate the eccentric top mount you have. set the eccentric to the widest point job done....although the proper wrc top mounts do give you a wider top seperation...
chip, yeah i know mate, but with coil overs fitted there is quite a bit of room to play with.
Escpecially if you do a full on WRC mod and extend the turrets (think martin did this on his) and fitted large top mounts.
Think Also Tony Ryan did this on his Thundersaloon.
standard lenth tcas will not give u full ajustment
i did martins stuff it alot of work to get right and with a saff i dont thing u got get much room with the arches deffo if its a 4x4 and i got big brakes u got no chance
Ian
it can all depend on how wide you want to go and where your measuring it, if your measuring it fom hub face to hub face then it can be done ( forgetting wheel to arch clearance, i must measure mine soon tbh as it is pretty wide at the front, so much so that i need to do something with the rear - looks a little .............odd
I can get some adjustment back on the turrets as I am using AVO coilovers, no arch liners and flared and rolled arches on my GpA Rally sapphire shell
I am willing to flare the arches more so as to help, something like this car:
this one shows them better:
I currently run 355mm 6pots under 18"Rl7s but willing to move down to narrow17s and 330mm brakes.
Markk what is it you use done yours, PM if prefered,
Ryan- If these work then I will give them a try, not seen them for a cossie, but will source and get a set to fit if these may work
All of this work is to get a cosworth drifting, I need the angle, more lock please
All that beautiful work and a snotty bit of old stick to prop the bonnet up , shame on you , lol .
I did use WRC top mounts on my car but i adapted them to go in the TAS style mounts as i didn't want to muller the turret top , was more for the reliabilty of the top mount than any extra lock , still not sure why you need it , and my track is Wide track GpA with 10" wide front wheels anyway .
MrC
Ive done the markk mods and altho better still not as good as the nissans, i think to move the tops out youll have to enlarge the turret top cos at mo mines right against the outer edge . As you im just trying to get a cossie drifting. Up and running now just needs a final map!!
The wr top mounts are steel.....
Regards
Ian
Originally Posted by Jano_OddKidd
how about drıve shafts
Mark, can you not get rack made, with a 'narrower' middle bit, so the rack can pull/push the wheels further? Or will the wheels hit the arches?
Will explain with elaborate hand gestures next time i am round, lol
OK, going to start this one again from the top;
I NEED EXTRA LOCK TO DRIFT MY 2WD GpA RALLY SAPPHIRE SHELL
I need it cos cosworth std lock is crap and I will get nowhere drifting, I already use the lock stop and its frankly a CRAP ANGLE! I can easily be beat by a std 200sx on std steering.
So I was recommended some mods for the steering that Markk used, different rack and moved TCAs etc etc but I had doubts about the top mounts not being moved, 3dr Wixsy has done the same mods- what did you use for top mounts on this setup though or are they std??
I dont get what the `LOL` and `lack of knowledge` comments are about
And Tony Ryan- cosworths have good lock for circuits but pretty poor for the road let alone drifting angle
Thanks for the phone call `Nightdivva`, top bloke, will take your advice, just need something more than crap std to work from
SteveH- thats what I`m missing, its the hand gestures that make it for me when explaining middly bits and things and stuff , I will understand totally when you have flapped about for a bit
Finally a pic of the offending motor, I would hate to have to sell up now because I couldnt get angle , though and RX7 or S15 would look sooo much better
Originally Posted by JonnyBravo
i dont like the diff control wires running that way
reminds of when i was younger and the chap at the end of my street was running an amp power wire AROUND the outside of his car in twin and earth
reminds of when i was younger and the chap at the end of my street was running an amp power wire AROUND the outside of his car in twin and earth [/quote]
Chap at the end of your street ? or YOU
what steering rack are you using to give you wider track
and here are some top mounts for you
https://passionford.com/forum/viewtopic.php?t=187720
ive been busted
You do realise my car is remote control.... and I couldn't even afford the wireless handset.....I have to chase it along the stage....lol
Ive amended the first pic for all you eagle eyed fookers....
FlashRS
13
31-08-2015 06:02 PM
track.focus'd
12-08-2015 05:53 PM
