FUSE BOX removal
hi folks how do i remove the fuse box from my 2wd 1989 saph? as i need to check the connections underneath
any help is much appreciated
cheers
luke
cheers
luke
cheers mate, always helpfull as usual, thee aa man checked all the earths, put it through his diagnostic comp and couldnt find anything, so logic suggested that it must be the connection on one of the wires under the fuse box
how do i fix one of the connectors and is it just take a pannel of in the car to acces it or just feel around blind??
Resident Wrestling Legend
be prepared for loads and loads of hassle
you can JUST about see the little nuts that hold it in place and you can JUST about pull it up far enough to unplug the connections
BUT
it's going to take DAYS rather than hours, easiest thing to do is to take the drivers seat out altogether, put a big mat on the floor to avoid the bumps in the floor, and get spannering
BUT
great
im not great at electrics and i need it done by next friday, is anyone any good at electrics on here as i am 100% hopeless, unless you count year 9 at secondry school elctronic classes
it's a proper cunt to do mainly because you can't pull the plugs out of the bottom of the box
i might have one floating baout but i think i threw it out the other week
i'll take some pics if i can find it to show you what i mean
i'm also breaking a granada but those boxes are different agian to the sierra
the fuse box is just a box of plastic with lots of bits of metal running about in it
think of a sandwich, now replace the filling with a strip ot metal, add another layer, and so on and so forth until you have 7 or 8 layers of metal
thats what the fuse box is built up like, so if oyu have a problem you HAVE to take it apart to see if you can sort it
what makes you suspect the fuse box in the first place thoguh?
my dash lights are out, the aa man suggested everything else and it was all working fine. so this is the only thing it can be. ill check the dimmer swith for the dash ligths as thats the only thing it could be.
when he stuck his hand through the car up to the fuse box the ignition lights came on but still no dash lights, thus i think its just a dodgy connection??
what do you think mate??
Originally Posted by Stu.H
restoration project
Good luck in sorting it mate, these simple things can be a right pain![Wall](https://passionford.com/forum/images/smilies/wall.gif)
![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
Im getting done on sunday hopefully
any help or suggestions would be appreciated!
Dr. Ickxs
15-09-2015 10:15 PM
